First Track Run After My Mods
Old Jul 9, 2007 | 10:12 PM
mrmint69's Avatar
I ran 14.93 before i did anything to my car. I only had CAI, Flowmaster & MAF. I just got back and ran 14.11 to 14.13 (5) times and one 13.95 going right after a 10 second car and got a 2.19 60'. My other 60' times were 2.39 to 2.45. I got great traction following the hot rubber trail a 10 second 70 Camaro left. I have 245's and have almost no traction. What would my times be with slicks if you had to guess? I like the fact i knocked a full second off but hope for more with slicks, 3:73, cutout & tune. I was figuring 13.25 to 13.75 and maybe a tune alone will get me close.
Old Jul 9, 2007 | 10:19 PM
Spllouder's Avatar
A tune will help alot alot . I ran 14.00 with all my mods minus the cutout which i installed today . what gears you have now ? 2.73 ? i hope with my cutout now i run in the high 13's some where .
Old Jul 9, 2007 | 10:33 PM
mrmint69's Avatar
The gears are 3:23 currently. My car brand new ran 14.2 and after 100K miles it ran 3/4 of a second slower. I am not sure how much the SC unit should take off my time but i figured better than it has.
Old Jul 10, 2007 | 01:23 AM
HardcoreRM125's Avatar
Something is seriously wrong ... Even if your pulling close to 2.5 60's, you should be running faster then 14's with a blower car.
Old Jul 10, 2007 | 07:16 AM
My Red 93Z-28's Avatar
What is the elevation of the track you are going to? If it is quite a bit above sea level that will cause slower times than some people are used to seeing on here due to the thinner air.
Old Jul 10, 2007 | 08:03 AM
SS MPSTR's Avatar
elevation and DA are huge factors.
Old Jul 10, 2007 | 08:21 AM
Z-RATED94's Avatar
I think your in the ballpark with your questimates. Work on that 60ft. like you said. Theres a lot to be gained there.
Old Jul 10, 2007 | 10:50 AM
'94 Bad A Z28's Avatar
Dude, you have way too much done to your car to be running STOCK times.
Old Jul 10, 2007 | 10:54 AM
Mortify's Avatar
I can see him getting 14s with no traction... you need drs... thats the only way you will get power to the ground.
Old Jul 10, 2007 | 03:30 PM
LT1Squirrel's Avatar
+1, i ran 13's stock all day
Old Jul 10, 2007 | 04:08 PM
96LT1TX's Avatar
-2
Density Altitude should be checked, what altitude/weather conditions where it at the track? I am guessing it is high, I also race at High DA's. At 5800ft DA and my 383 it takes a 2.0 or so to run my 13.0@109. Also what was your MPH? There still may be something wrong w/ your car, but at least tell us the DA and MPH so we can better judge your times. 60' definely needs help though.
Old Jul 10, 2007 | 07:54 PM
mrmint69's Avatar
Talking
Elevation is 2461 ft. Temperature was 80-90 degrees. It was 100 that day so by 9:00 it started to cool off a little. Every run was right around 101 mph. I never let the car cool down and ran 6 times in an hour since it was so empty. My first run was 99 but i let off the gas before i crossed the finish since the finish is misleading. I hear people say if you put headers on but don't upgrade the rest of the exhaust it is a waste. I have seen reports of up to 40 horses with a cutout. I sure hope this is one of my problem. I was told the car had the cam upgraded and has a shift kit so it is hard to get an accurate tune without knowing for sure. I am hoping for a tune by sending in my scanned runs. I bought some Goodyear 315's so i will try them at the track but they are more for the steet and i will get some Slicks for the track.
Old Jul 10, 2007 | 09:13 PM
oneclean97z's Avatar
with my current mods i ran a best of 13.6 something, cant remember the trap speed though
Old Jul 10, 2007 | 09:24 PM
2QUIK6's Avatar
With a 6.5psi supercharger, there's something still not right even at alt. Have you had it tuned by a knowledgable LT1 tuner, are you monitoring for knock and are you seeing any?
Oh, I just read your last post and it doesn't sound like it has a tune...sounds like you just recently got the car. I bet someone just slapped on the SC and thats all they did and you are getting knock like crazy. You don't mention it, but spark retard will kill your times, not to mention your bearings and head gaskets or more very quickly with a SC application.
Feffman
Oct 9, 2015 05:42 AM
192cobra
Jan 26, 2015 12:12 PM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
