What exhaust system do you run on your LT1?
Old Jul 9, 2007 | 10:02 PM
zo6vette's Avatar
What exhaust cat back system does everyone here use?
Old Jul 9, 2007 | 10:08 PM
NVetro's Avatar
I have the SLP Loudmouth, original one. It is flowing through a 3" ypipe without cats, and a set of jet hot long tube headers. It was cool and everything for awhile, but after awhile it started to sound terrible and like a tractor trailer with all the poping and stuff. I sounded even more horrible with my 383....mind u its cheap, flows good, and served me well since 2002ish.
I have my new true exhaust waiting for me, it consists of the original long tube headers, 3" piping out of the collector, to a 3" H-pipe, and then to (2) 3" outlet/inlet 16" long Dynomax Bullets. Should sound sweet, I was going to do an x-pipe rather then h-pipe but with the spohn adj torque arm w/ front mounted ds loop there is no way i am going to have any clearence. Plus at the end of the day, its kinda nice, being able to drop the h-pipe quickly and then work on everything
Old Jul 9, 2007 | 11:53 PM
mn96ss's Avatar
I run slp dual cat shorties ( flame suit ) with 1 3/4 primaries, ory into a 3" in pipe into the slp 2otl. sounds really good and hopefully see some results at the track as well.
Old Jul 10, 2007 | 12:16 AM
urbaNHunter44's Avatar
dumped headers
Old Jul 10, 2007 | 12:22 AM
speed_demon24's Avatar
Jethots into the TSP x-pipe with spiral flows run out the back under the axle.
Old Jul 10, 2007 | 07:03 AM
My Red 93Z-28's Avatar
Hooker LT's, y-pipe, 3" manual cutout, flowing into a Delta 40 Flowmaster single inlet, double outlet on the driver's side.
Old Jul 10, 2007 | 07:08 AM
Harvey's Avatar
Thumbs up
Kook's stepped headers into the TSP X-pipe system through DynoMax bullet's and dumped before the axle.
Old Jul 10, 2007 | 07:09 AM
What are the advantages of stepped headers? Are they only for engines that have been modified to a certain point?
Old Jul 10, 2007 | 07:34 AM
Harvey's Avatar
Thumbs up
I don't know if there is any real advantage right now with my current setup, but I got them because eventually I will be doing some type of big motor setup with big heads and cam and wanted the best flowing exhaust system out there. Trying not to buy things twice.
Old Jul 10, 2007 | 07:37 AM
mthegodfather's Avatar
Hooker LT's, y-pipe, and bullet.
Old Jul 10, 2007 | 08:01 AM
SS MPSTR's Avatar
Jet Hot LT's, Bassani true dual with x-pipe, Magnaflow-spec muffler.
Old Jul 10, 2007 | 08:25 AM
Z-RATED94's Avatar
Pacesetter longtubes, no cat, Edelbrock single 3'' exhaust, with a cutout for the track.
Old Jul 10, 2007 | 08:56 AM
Bobsep84's Avatar
Hooker cat-back..
Old Jul 10, 2007 | 10:05 AM
NJLT1SS's Avatar
Kooks 1 3/4 to 1 7/8 long tubes, custom 3 inch Mufflex y to a Flowmaster 4" merge collector, 4' Mufflex cat back with a 40 series 2 chamber Flowmaster "race" muffler.
Nick
Old Jul 10, 2007 | 12:45 PM
2000GTP's Avatar
Pacesetter longtubes, dual catted off-road y-pipe, cutout, Magnaflow catback.
