Anyone have problems with MSD opti + Delteq???
I've been running a Delteq for a while and it seemed OK but I recently put in an MSD opti. The car cranks a long time before starting and if the battery is a little bit low it will crank but not start. Anyone else having similar issues? Or maybe it's something else??? Suggestions?
Not the specific problem you're having, but you need to check-out these two links and threads on the MSD Opti. Could possibly same you some trouble with your MSD.
WD
http://web.camaross.com/forums/showthread.php?t=526760
http://web.camaross.com/forums/showthread.php?t=525186
WD
Thanks for the info. I think I may have figured out what is happening and after doing more research I'm ruling out the possibility of the MSD opti not getting along with the delteq. I think my injectors aren't working right and I think I know why. Thanks again.
