Starting car after 8 months change oil?
Old Apr 16, 2007 | 09:48 PM
WarMachine's Avatar
Hello folks,
My car has been sitting for 8 months since I've been away and I have not been able to work on it. Before I semi rebuilt the motor, I put new oil in the car and everything. I only ran the car for 5 minutes because of a bad water pump. Now I still need to break the cam in and it's reccomended that I run the car for 20minutes at 3K RPMS, then change the oil afterwards. Since I have to change the oil anyway should I just use the oil that's been sitting in the pan for 8months to break the motor in? Or should I drain it and add new oil then break the motor in?
Old Apr 16, 2007 | 09:59 PM
mrmint69's Avatar
I would say your safe with the old oil for 20 minutes off running. I would do it if it was my car because it is probably in need of a good flush and this would be a great time to do it. I would not change the filter until after the run either way. How many miles it had on the old oil is also important. $12 for 5 quarts of oil is not that much.
Old Apr 17, 2007 | 04:07 AM
SS RRR's Avatar
I assume you have a LT1? If so, roller cams do not need to be broken in. And yes... change the oil before starting.
Old Apr 17, 2007 | 08:15 AM
2000GTP's Avatar
8 months is a long time for condensation to get in there, I would change it before starting.
Britbilly
Jan 7, 2015 08:49 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
97 RedSS
Jun 10, 2003 07:58 PM
