alternator mounting
Old Mar 29, 2007 | 10:00 PM
custom95's Avatar
alternator mounting
Ok, I'm putting my accessories and other stuff back on my 94 lt1 and I've got the y-shaped alternator bracket on but on the left mount for the alternator there are no thread in either the main accessory bracket or the alternator. Am I missing another bracket on the back side or do I use a nut and bolt? Looking at the following pic it would be the left side of the alternator. thanks.
Old Mar 29, 2007 | 10:19 PM
red67camaro's Avatar
All I get is a photobucket ad when I click the link.
If this is the thicker of the two mounting points on the alternator, it just uses a bolt and nut.
Old Mar 29, 2007 | 10:22 PM
There is a bracket on the very back that comes from the front exhaust manifold stud. A bolt threads through that and into the back of the alternator. The long boss on the lower side of the alternator takes a long bolt and nut to attach it to the accy bracket.
This might help.
Who put that ugly pulley on the otherwise clean looking engine?
Old Mar 29, 2007 | 10:40 PM
custom95's Avatar
This might help.
That helps a great deal, thank you. I'm also putting headers on so does that bracket that mounts to the manifold stud becomes obscelete?
Old Mar 29, 2007 | 10:42 PM
custom95's Avatar
My bad, I screwed something up on the photo- thanks
Old Mar 29, 2007 | 11:32 PM
It depends on what you want to do with it. Some people never put it back on, because it is such a pain to deal with (even without headers). It's there for a reason, but from what I have read, people that have deleted it have not reported any major issues.
Old Mar 29, 2007 | 11:56 PM
Stock exhaust manifolds on an LT1 use the "extra" bolt hole in the head which accomodates the aforementioned bracket.
I was able to make a spacer to retain the bracket using the same hole in the head which would otherwise be blank as my headers use the standard bolt hole. But then my Camaro is a '67 and I'm using first gen headers.
Old Jun 9, 2007 | 10:55 AM
Jim D's Avatar
Thanks for the pic Shoebox, just what I was looking for before I head out to the garage!
Old Jun 20, 2007 | 06:41 PM
RPWS6's Avatar
I am running hooker long tubes and the canton tall valve covers. I am unable to use either bracket. Does anyone else have this issue? Any sugestions? I am thinking about cutting the Y piece and just using it to the rear of the thin tab on the alt????
Old Jun 20, 2007 | 09:21 PM
custom95's Avatar
I'd be careful because I've seen a few threads where people have had their accessory brackets break when they leave the y-shaped bracket off. Grant it, using one mounting point would be better than nothing but still might not be enough support to keep it from breaking.
Old Jun 20, 2007 | 09:40 PM
tnmotown's Avatar
just like custom95 stated above, if you dont have that y-bracket supporting your alternator (y-bracket from intake manifold to back of alternator) IT WILL SNAP THE ACCESSORY BRACKET!! I know this from experience because i at LEAST broke my acc. bracket 3 times! I finally found out from someone that there was a bracket supporting the alternator to the intake manifold.
The bottom bracket where it mounted up to the stock exhaust manifold should be fine off. I dont have it on and have no problems.
Old Jun 20, 2007 | 09:58 PM
RPWS6's Avatar
Hopefully the one(1/2 Y) to the rear upper tab will be OK because I need the VC's for clearance and there is no way the full Y will fit????? I also want to keep my air so a relocation kit is not really an option. I could try to relocate the Y part further up and cut and weld it?? Possibly? I have a mig welder but I'm not a great welder. I only drive about 1000-1500 miles a year but they are usually pedal down miles
Aug 5, 2015 08:35 AM
Thirim
Jul 30, 2015 01:29 PM
Jlo
Jul 29, 2015 03:52 PM
Jul 10, 2015 02:23 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
