Still Have a Miss
Old Mar 22, 2007 | 09:11 PM
bitchin94's Avatar
Still Have a Miss
Ok so my car started to miss fire so I changed plugs and wires, AC Delco Gaped at .45 then and the wires are MSD 8.5s. It still was missing and I changed my opti and coil mew GM unit on the distributer and an O'Reillys unit on the coil. It is Still Missing on one F***ing cylender except every once in a while it will kick in on all 8 but then go back to 7. It never runs on all 8 more than a few minutes. So WTF could it be
Old Mar 22, 2007 | 09:50 PM
Voridaeus's Avatar
You're positive it's a spark issue and not an fuel injector? Also you should try taking off a valve cover and make sure valve train on that cylinder is functioning correctly and nothing is amiss. Also a compression test wouldnt be a bad idea.
Old Mar 23, 2007 | 07:46 AM
93Z286Speed's Avatar
try LIGHTLY tapping on the fuel injectors with a screw driver or something, that usually will get them to unstick aslong as there not too bad. Id also recommend the GM in tank fuel injector cleaner. Its a little more then an off the wall brand, but it works very well.
Old Mar 23, 2007 | 02:20 PM
2000GTP's Avatar
To rule out the injector, you can swap it to another cylinder. If the misfire follows to that cylinder, then you know you have an issue with the injector.
93 RedBird
Nov 15, 2015 08:24 AM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
tommalcolm
Sep 11, 2015 03:39 PM
