At what point should one install the GM white oil pump spring...
Old Feb 22, 2007 | 11:07 AM
wrd1972's Avatar
I am building a 355 with LE2 head and LE1.5 cam that will rev to 6.4K.
Main bearing clearances are .002" and rod bearing clearances are .0025".
Rod end-play clearances are .020", a tad larger than GM spec.
At what point should one install the GM white spring (3848911 ) into a stock volume oil pump. A lot has been said about bearing clearances but I dont know if my setup warrants this. I am at the point where I can still make this change but the door is closing.
Thoughts?
Old Feb 22, 2007 | 11:42 AM
I am not an oil pressure expert, but I don't know why you would not want to use it. It's not like that spring makes the pressure sky high and if the engine is goiing to spend more time at high RPMs, I think the higher pressure would help keep it from trouble.
Old Feb 22, 2007 | 12:05 PM
seawolf06's Avatar
It doesn't increase pressure, it just allows the pressure to build to a higher level before it bypasses it off. Correct?
You should use it on almost any application.
Old Feb 22, 2007 | 01:11 PM
Well, the oil pressure gauge is going to read higher. What does that mean to you?
Old Feb 22, 2007 | 01:43 PM
wrd1972's Avatar
Just ordered the spring from the dealer, it will go in my new Melling select 10553 standard flow oil pump as soon as I get the pickup welded on.
I assume that if the pressure were higher than desired you could run thinner oil, right?
Old Feb 22, 2007 | 03:17 PM
Bersaglieri's Avatar
How do you change the spring? How much does it increase it?
-Dustin-
Old Feb 22, 2007 | 03:47 PM
wrd1972's Avatar
-Dustin-
You have to remove the cast cap on the oil pump where the tube sticks in. Then drive out a roll pin then the spring comes out. It is easy to once you are at the oil pump. The thing costs less than $3.00 at the dealer.
Maybe someone will chime in on the gains.
Old Feb 22, 2007 | 04:01 PM
seawolf06's Avatar
I read somewhere the melling select pumps have a bolt instead of a little push pin, but I'm not sure. Does yours still have the pin?
Old Feb 22, 2007 | 07:47 PM
wrd1972's Avatar
It was a pin I pulled out this morning.
Old Feb 22, 2007 | 07:52 PM
mdacton's Avatar
the mellings select i think doe have a bolt.....the regular mellings don't
I just got a blueprinted pump today.....
some people used to put a washer in there in front of the spring...it good insurance so for $3 why not right?
good luck
Old Feb 22, 2007 | 11:58 PM
Dan Parker '96's Avatar
Stock pump is good to 7K rpm for many thousands of miles. No need for an "upgrade".
Old Feb 23, 2007 | 02:05 AM
Westlotorn's Avatar
What pressure is the White Spring supposed to give you, what increase should you expect. It would be good to know before installing it. Too high of pressure is a waste of horsepower. In an engine that will redline at less than 7,000 RPM you would never need more than 60 to 70 pounds of pressure. You are going to have leakage around the Rods and that will lower the pressure some. A high volume pump might be more what you need to keep your pressure up since the rods are slightly loose.
Old Feb 23, 2007 | 06:52 AM
It's advertised at about 70 psi.
Old Feb 23, 2007 | 08:07 AM
wrd1972's Avatar
I cant run a high volume pump without an aftermarket oil pan replacement. There are no aftermarket oil pans that will work with my AS&M headers, the driver side routes the same way as the stock manifold.
Old Feb 23, 2007 | 08:45 AM
You don't need a high volume pump, IMHO. You'll be fine.
