Xfi 467
Old Feb 18, 2007 | 12:59 PM
CrossupBill's Avatar
Xfi 467
Would this cam work with a Vig 3500 and a 3.73? With headers, and some other bolt ons. Stock heads. The specs are as follows:
Comp Cams XFI LT1 Camshaft, 230 / 236, .576 / .570 113 LSA, Strong mid-range and top end power. Headers, exhaust, gears, converter, computer tuning recommended.
Thanks in advance.
Old Feb 18, 2007 | 01:22 PM
89TramsAmGTA's Avatar
Stock heads. Might be a problem. Don't think the stock heads can take the lift.
Old Feb 18, 2007 | 04:02 PM
aboatguy's Avatar
It will work well with the stall and the gears; however, as already noted it's probably too much cam for bone stock heads.
Mike
Old Feb 18, 2007 | 04:06 PM
maro z28's Avatar
I thought that was the 280XFI?
Old Feb 18, 2007 | 04:13 PM
aboatguy's Avatar
I bet they are the one and the same.
I have a COMP CAM card in my hand for a Part number 07-467-8, the next line says ENGINE: LT1 280XFI HR-13
Old Feb 18, 2007 | 07:19 PM
Z-RATED94's Avatar
I say go for it and put some decent heads on when you get the money.
Old Feb 18, 2007 | 08:20 PM
Well that lift is with 1.6 rockers I believe, with 1.5s which I have I think that the lift comes in at around .540
Other than too much lift does this cam sound pretty matched for my combo? Is there something better out there for me. I have heard about Lloy Elliot cams, any count?
Old Feb 18, 2007 | 08:38 PM
Z-RATED94's Avatar
Can't use your stock rocker arms with a cam that has any kind of lift like that. You need to purchase a set of Lloyds heads to be able to purchase a cam from LE. Unless he has changed his policy? Or you can get a custom cam from Bret Bauer who designs the cams for LE. Talk to both, their very helpfull.
Old Feb 18, 2007 | 08:56 PM
Yeah I know about the stock rockers, but my main concern is the retainer to guide clearance. Will a .540 lift cam clear in taht aspect?
Old Feb 18, 2007 | 09:37 PM
SStrokerAce's Avatar
.540" has no problem with guide to retainer contact.... and yes gotta get the Cam Only stuff straight from me. XFI 467 is not bad, just hard to control for the RPM you need to turn it to get the most out of it.
Bret
Old Feb 18, 2007 | 09:42 PM
Bret
That is good to hear. What do you mean by the hard to control statement? Valve float???
Old Feb 18, 2007 | 09:53 PM
Yep, XFI stuff even with light parts and spring pressure is hard to keep stable over 6200rpm, that's why all the RPM ranges in the catalog end in the 6000-6200rpm area. Even with lots of duration.
Bret
Old Feb 19, 2007 | 12:31 AM
Well that makes sence, that is a pretty aggressive lobe.
Old Feb 19, 2007 | 12:22 PM
The XFI's make for a good street cam with those shifting in the low 6000's.
KamikaZ28
May 28, 2015 12:45 AM
Fastbird93
May 22, 2015 08:28 PM
89TramsAmGTA
3rd Gen / L98 Engine Tech
15
Mar 3, 2007 12:47 AM
engineermike
Advanced Tech
10
Jul 20, 2006 07:54 PM
89TramsAmGTA
Advanced Tech
16
May 17, 2006 08:29 PM
