Cam Opinions...
Old Nov 29, 2006 | 07:51 AM
RealQuick's Avatar
Cam Opinions...
Well, I finally got around to ordering some more parts for my engine build. It wil be a single turbo T-88 383ci setup that will need to pass the sniffer. Here are some specs on the engine:
HPE 383
LE ported AFR210's
224/224 .573/.565 114lsa straight up
M6 Tranny
9" 3.55 Detroit Locker
blah
blah
I would like this setup to sound stock and still make peak power around 5600-5800rpm (shift around 6000-6200rpm). The main goal was to pass emissions. I am going to break the motor in N/A this summer before the turbo goes on and want to dyno the N/A setup before as well. I'm hoping for 370-380rwhp... even with 8.5:1 compression. What do you cam guys think as far as hp peak rpm? Are my expectations reasonable? Should pass the sniffer right with a good tune...
Old Nov 29, 2006 | 11:10 AM
reamo04's Avatar
not really what your asking, how much PSI are you going to be running on that turbo?
Reason I ask is I am getting a procharger and am trying to figure what CR i will need to run 15-20psi
Old Nov 29, 2006 | 11:13 AM
RealQuick's Avatar
I want to know if my estimates on the peak HP rpms is correct, or do people think it will peak higher or lower. I plan on running 12-15psi on pump with methanol. My CR is 8.5:1.
Old Nov 29, 2006 | 01:42 PM
SStrokerAce's Avatar
Between HPE building your short block and Lloyd doing your heads you have two good places to ask about the cam.
Bret
Old Nov 29, 2006 | 01:43 PM
What's the rest of your setup? What blower and pulley? 8.5:1 is pretty tame and should be fine.
Bret
Old Nov 29, 2006 | 01:50 PM
T/A KID's Avatar
I think Realquick's setup is a Turbo?
I think your about right to where the power should be on a N/A build, the thing will be nasty with boost.
What runner volume did he get the 210's to, 217??
Old Nov 29, 2006 | 02:10 PM
RealQuick's Avatar
Bret
T-88 turbo... looking to run 12-15psi on pump.
Old Nov 29, 2006 | 02:11 PM
RealQuick's Avatar
What runner volume did he get the 210's too, 217??
Correct. The heads I think actually finished out at 213cfm. I think with the right tuning 800rwhp shouldnt be a problem... now traction is a another story
Old Nov 29, 2006 | 03:03 PM
Sweetred95ta's Avatar
T-88 is huge ...
Old Nov 29, 2006 | 03:13 PM
T-88 IS HUGE!
Why that big?
RealQuick's Avatar
Originally Posted by Sweetred95ta
T-88 is huge ...
Since I need to pass the sniffer in MA, the cam can be mild ... and I'll let the turbo make all the power
Old Nov 29, 2006 | 03:16 PM
RealQuick's Avatar
T-88 IS HUGE!
Why that big?
Best eficiency for a 383ci with a T4 flanged turbo is the t88. The T76 would have done fine... but I am greedy
Old Nov 29, 2006 | 03:17 PM
godspeed1976's Avatar
T-88 is pretty big. Wouldn't you benifit from a more effecient turbo rather then a T-88? Now I am not experianced in V8 Turbo setups so I maybe way off. It would take a lot before you spool and I am not sure what your application (ie. drag racing, top speed) is.
Old Nov 29, 2006 | 03:25 PM
RealQuick's Avatar
For a T4 flanged turbo, the T88 is the most efficient turbo available for 383ci engine (when looking at a compressor map and comparing air consumption versus boost). A smaller turbo will be less efficient, but provide faster spool up du to smaller wheel. A T76 would be fine, but I want to put down some numbes to compete with some local guys... show them an LT1 can make big power. This car is a steetcar... maybe hit the track once a year.
Jon
Old Nov 30, 2006 | 01:50 AM
1997blackz28's Avatar
I too am new to v8 turbo setups but i have had quite a bit of experience with v6 turbo cars. at what rpm will 383 motor spool a t88? and is 12 - 15 psi in the power band of that turbo? i just ask because in my experience with smaller motors (i know that makes a big difference in spool and all) a t88 has to spin pretty high to hit full boost, and 15 psi would barely spin the compressor wheel. this is all on a 3.0L supra motor though so i have no idea how it would react on a much bigger 383. im nt saying your set up wont work or anything basically just trying to educate myself a bit. thanks.
