Back fired out the intake and won't start...
Geez, I can't believe I'm posting one of these threads, but here it goes... I just put the timing set, timing cover, and opti on. I decided to fire it up to make sure it would start and run. It started right up and idled perfectly. I walked up to the front of the car and popped the throttle a couple times. Everytime I did, something would hit me in the face. Well, it turns out that one of the drop lights I was using burned a hole in one of the fuel lines. So, I cut the bad section out and went and bought a slightly bigger flexable fuel line. I put the two ends in and hose clamped it (gently). I went to fire it back up again and it back fired through the intake and now it won't start. It doesn't even act like it wants to fire. I checked the fuel pressure (to make sure I wasn't pinching the line), and it's 42 psi with KOEO and ~38 psi while it's cranking (not leaking out of the patch what so ever). So, I ruled the fuel out. I then thought it maybe jumped time, but it wasn't acting like it (hard to turn over). Well, the dots lined up perfectly. I even took the opti back apart and it seems fine. I haven't verified that I have spark yet, but what could cause it to do something like this? Any help is appreciated. I'm going to bed; I'm tired.
After messing with the Fuel lines did you happen to mess with the Plug Wires. Last week I got my Delteq coil packs on the wrong spot and had a backfire through the intake b/c my valve events were all messed up
. Fixed the problem after I fixed the coil packs
No, that's what's weird; I didn't touch anything except for splicing the line back together. Perfectly smooth idle to nothing at all.
That's what I was thinking, but I verified that both the plug wires and timing were in check. I'm at a loss. I won't get a chance to do anthing more to it until after Thanksgiving weekend. I'll revive the thread and let you guys know what I've done/tried. Any more suggestions would be much appreciated.
), so I used the old one. I'll check that when I get the chance.
Yeah, I'm pretty sure it's a fubar'd combo of opti.
When my opti blew I had a huge backfire flame come out of my cutout. I was in the burnout box at the track at top of 2nd gear
Shoulda been there
Shoulda been there
FYI, anyone, GM opti's from Jason Cromer run you $243 shipped to your door, can't beat that price and I'm not convinced the MSD optis are any better talking to a few local folks that work on LT1s alot, they haven't had but about 50% success with them.
