Help! No Spark from the coil
I changed the ICM and I'm still getting no spark at the coil.
I thought it might be the coil so I mickey moused a new coil to the connectors and still no spark.
I swapped out the PCM and still no spark.
The car has been sitting there for a year.
Don't tell me I have to check for continuity in all the little wires now.
Advise please.
Oliver
Advise please.
Oliver
Some testing info.
Check the fuse box under the hood. Mine did the same thing a long time ago and turns out it was just a blown fuse under the hood on the driver's side under that little black box. If this isn't it is could be your optical sensor.
Good Luck
Good Luck
Shoebox, Your diagrams are the best. I'll try the test you provided. I always thought the the opti's work came after the icm.
Nostang, I've check the fuses and they look good.
Thanks guys
Oliver
Thanks guys
Oliver
Well, with my friends help we've figured out the problem. One of them anyway. After spending money on a new ICM and coil we found out the optispark optical pickup connector is corroded. When we pulled it, it was a green mess and all the pins were gone. So the the PCM was not getting any signal to send to the ICM.
This is the second time I'm changing the opti connector because of corrosion.
I'll keep you guys updated on whether or not my car starts after the opti swap.
I know i've bought just the connector before for about $5.
But I forgot which dealership I bought it from and the few I called this time said they only sell the whole harness for $166.
Anyone have the part number for just the connector or subharness?
Oliver
Oliver
