Garage *SALE*
Old Dec 4, 2005 | 02:56 PM
FASTFATBOY's Avatar
Garage *SALE*
Most of the parts off a 94 Z28
Factory fans $100
GM vented opti, NEW in box $275
Hooker 4 inch to 3 inch reducer NEW $10
Factory mass air with Mallory billet aluminum ends $125 (ends are new)
Crower solid roller lifters, 2 sets, dyno time only, part numbers:
66292 (intake offset) 66290 (standard) with tie bars and will work with LT1 block. $325 each set.
325/50/15 BFG Drag Radial, sidewall is damaged near tread where the fenderlip cut it, new, good for fitment purposes(or maybe good to run, I decided not to) $35
Factory auto trans cooler lines $45
ABS sensor, bolts into factory housing over ring gear, $10
94 timing cover $20
GM knock sensors, 2, 10 each
Factory windage tray $10
Autozone reman starter, used for 2500 miles $75
Factory MAP sensor $20
Factory harmonic balancer $50
LS1 Corvette oil pan $75
Mallory billet aluminum radiator hold down NEW $60
Factory 94 Z28 rear seats, excellent condition, two tone grey $75
Energy suspension poly trans mount NEW $20
Moroso drivers side solid motor mount, NEW $10
OBD1 ALDL data cable kit, you must assemble this kit NEW $40
Oil pump drive hold down $15
GM oil pump drive NEW $25
Prices do not include shipping, parts are located in Mobile Ala, 36619
NO PM's PLEASE
E mail
Speedadikk@Comcast.net
Thanks fer lookin'
David
Old Dec 4, 2005 | 03:26 PM
NVR2QIK's Avatar
Re: Garage *SALE*
Dave, I might know somebody who could use dem der cooler lines here in town. I'll let ya know.
Joey
Old Dec 4, 2005 | 03:56 PM
FASTFATBOY's Avatar
Re: Garage *SALE*
Joey
Thank yee
David
Old Dec 4, 2005 | 05:57 PM
DonHood's Avatar
Re: Garage *SALE*
Do you know what it takes to use a vented (95+) opti on a 94 car? Do you only need the elbow with the port on it, and the vent line that runs between it and the opti? Is there anything else I would need? Thanks...
Old Dec 4, 2005 | 07:57 PM
FASTFATBOY's Avatar
Re: Garage *SALE*
You would need the 95 and later timing cover also.
David
Old Dec 5, 2005 | 10:29 AM
FASTFATBOY's Avatar
Re: Garage *SALE*
Tdt
Old Dec 6, 2005 | 07:26 AM
FASTFATBOY's Avatar
Re: Garage *SALE*
TOP..offers, hell I dont know what some of that stuff costs
David
Old Dec 6, 2005 | 08:01 AM
KGRESOCK's Avatar
Re: Garage *SALE*
I'll take the solid mount.
Send me a PM
Kevin
Old Dec 26, 2005 | 12:14 PM
FASTFATBOY's Avatar
Re: Garage *SALE*
After X Mas bump. All parts still available
David
Old Dec 27, 2005 | 02:28 AM
jssws-6's Avatar
Re: Garage *SALE*
Have any pics of Mallory billet aluminum radiator hold down NEW $60
Interested ( is it the piece that takes the place of the black plastic cover)
Old Dec 27, 2005 | 06:02 AM
FASTFATBOY's Avatar
Re: Garage *SALE*
Yes it is, I will get pics to you tonight.
EDIT I GOT IN LATE WILL DO IT ASAP THOUGH, part is NEW never mounted, still in plastic.
David
Old Dec 27, 2005 | 11:03 AM
92zcamaroperson's Avatar
Re: Garage *SALE*
That aldl data cable would work on my 92z28 right? Then all I would need is a laptop and the software? Is that $40 shipped? email is guitarguy00@gmail.com
Old Dec 27, 2005 | 11:55 AM
IllusionalTA's Avatar
Re: Garage *SALE*
Sent ya a email on the mount.. Don't know if it's been sold as of yet...
Old Dec 27, 2005 | 05:44 PM
Live for TAs's Avatar
Re: Garage *SALE*
Sent an email for a knock sensor.
Old Dec 27, 2005 | 10:18 PM
FASTFATBOY's Avatar
Re: Garage *SALE*
I am not sure on that.
Yes freescan or the like.
SHipping around 5 to 6 bux on that item.
David
