Third Gen Stuff: 9 bolt, 700r4, TPI, gears.
Have a bunch of stuff for sale off my 88 firebrid formula......
-SLP ported Intake Runners
-Richmond 3.73 gears for a 7.5' 10 bolt BRAND NEW
-700R4 transmission 110k shifts smoothly with shift kit
-9 bolt rear with 3.27s and good posi.
-Ported TPI plenum
-Stock TPI intake manifold
-Stock 48mm throttle body
-Stock fuel rails and injectors
-Stock fuel pressure regulator
-Ignition coil bracket
-EGR soliniod
-Stock TPI intake runners
-Thermal Time Sensor for TPI
-Water neck and upper rad. hose
-700R4 trans crossmember
-Stock Torque arm
-Stock Crank Pulley
-Stock Lower Control Arms
Make offers.....will email pics if wanted.
-Ported TPI plenum
-EGR soliniod
-Stock Torque arm
-Stock Crank Pulley
Jul 4, 2005 05:00 PM
