Supporting Vendor Group Purchases and Sales GPs/SALES CAN BE MADE BY SUPPORTING VENDORS OF THIS SITE ONLY!
“Already made” Over The Valve Cover Ignition wires for LT1/LT4.
Old Aug 24, 2005 | 01:27 PM
Maldo's Avatar
Elitesparkplugs.com has “Already Made” OVER THE VALVE COVER IGNITION WIRES to fit your LT1/LT4 engine.
Don’t want to waste your time cutting and sizing up ignition wires. These wires are precut & numberd for a perfect fit.
Sample 1 Click here
Sample 2 Click here
Sample 3 Click here
Sample 4 Click here
Warranty: When have you ever heard of a warranty with ignition wires!!!
Elitesparkplug.com back up their ignition wires with a Limited LIFETIME WARRENTY. (Call for details)
Personalize Your Ignition wires with some of the options below.
1) Armor Heat Protection:
Each wires set can be upgraded with our Armor Heat Protection, which helps to protect from chaffing and heat (500 degrees direct heat & up to 1200 degrees radiant heat).
2) 8,9,10 mm wires available:
3) 8mm Colors:
Standard Colors:
Black, Blue, Neon Blue, Neon Green, Red, Yellow
Upgrade color optionr:
Neon Red, Neon Pink, Neon Yellow, Neon Blue, Beige, Carbon Fiber, Nitrox, Patriot, Orange, Yellow, Purple, Clear , White, Gray (call for details)
4) 9mm colors:
Standard: Blue, Red
Upgrade option
Red, Black, Blue, Green, Neon Red, Neon Pink, Neon Yellow, Neon Blue, Beige, Carbon Fiber, Nitrox, Patriot, Orange, Yellow, Purple, Clear, White, Gray
Old Aug 24, 2005 | 02:08 PM
GMH94Z28's Avatar
Re: “Already made” Over The Valve Cover Ignition wires for LT1/LT4.
I just put some of these on my car while i was installing headers and they are great. Thanks again
Old Aug 24, 2005 | 05:12 PM
chevy94c's Avatar
Is this for the opti or delteq ignition?
Old Aug 24, 2005 | 06:09 PM
Maldo's Avatar
For this particular post it's for the Opti set up but we also make custom wires set ups for Delteq systems.
click here to see our custom wires for the Delteq system
pic 2
Old Aug 24, 2005 | 08:40 PM
chevy94c's Avatar
Nice
I am going to order the opti setup. It's been a few year since i have changed my wires.
Old Aug 26, 2005 | 04:57 PM
Maldo's Avatar
ttt
Old Aug 26, 2005 | 07:42 PM
yotaman96's Avatar
I was about to order some, but when I go to checkout it gives me this message.
yhst-16788112107662 is not open for business.
Ordering is allowed for testing purposes only.
Didn't want to order if it wasn't going to go through.
Tim
Old Aug 26, 2005 | 11:56 PM
Maldo's Avatar
Tim
Hi not to worry it's just a software glitch ....... you can still place the order without a problem
Old Aug 27, 2005 | 04:09 PM
Green G0blin's Avatar
can you pm me with prices? also where would i get the looms from?
Old Aug 27, 2005 | 11:13 PM
pricelessz28's Avatar
just installed a set of the 10mm ovc wires. they are awesome. definitely the easiest set of wires i have ever installed.
Old Aug 30, 2005 | 05:16 PM
Maldo's Avatar
Hi click here to view prices.
The best wire looms to use are from "made for you" which can be purchased from a number of dealers click here for their web site to see the nearest location or take a ride down to you local parts store. Most carry similar brackets.
HectorM52
Jul 30, 2017 11:46 AM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
