Anyone know max lift for CC941 valve spring?
Old Aug 20, 2005 | 09:18 AM
ZBLKHELLRZR's Avatar
Question Anyone know max lift for CC941 valve spring?
I've searched and found conflicting results. Max .500 w/ a stk height but others report .560 being max. CC's website doesn't say much I know people use them here as well. Lift on my cam is .544/.560 w/ these springs w/ 140lb seat pressure w/ TI locks and retainers.
Changing the cam and want to keep these springs but need to know what they can take. Thanks.
Old Aug 20, 2005 | 10:13 AM
OldSStroker's Avatar
Re: Anyone know max lift for CC941 valve spring?
From Comp's site, coil bind is @1.130 and with 140 on the seat, your .560 lift would put them about .050 or a smidge less from coil bind and around 390 # over the nose of the exhaust.
That might be pushing it.
Old Aug 20, 2005 | 05:12 PM
Thanks. Hell I just may get the same cam w/ just a wider LSA then 115 vs th current 110 LSA. I don't rev it past 6300 and w/ the hydra kit already there I should be ok.
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
