Delteq Opti-direct Sale get is while supplies last
Hi guys per-request.
Check ou t thread
Hi guys,
GP prices for the Delteq Systems
This is a great offer and for limited time. We have allocated a limit amount of units for this sale. . This sale is from May 2 to 20 (7 order minimum )or when we are sold out of units which ever comes first (you have to mention this ad to receive discount.)
Choice of mounting locations:
F-body = Valve cover * or lower Radiator mount.
Note: * (Traction control equipped cars can not use valve cover mount.)
Corvettes/Impalas = Valve cover mount only.
Your choice of:
8mm (different colors + heat protected coating. (500 degrees direct contact and 1200 degrees radiant0
Or
9mm (available in red or blue) (heat protection available at additional $10.)
We will not charge or cash checks until the minimum orders are met
Check ou t thread
Hi guys,
Your choice of:
Or
Re: Delteq Opti-direct Sale get is while supplies last
Can this work with a FAST EFI system which is setup for an optispark? Is there a provision for mounting on the firewall, where the heater core used to be?
Hi yes we have a harness that will work with this system ($45 extra)
I am sorry but, at this time we have only two locations valve cover /lower radiator (f-body only).
Originally Posted by StickMaster
Thanks Maldo, Thought you forgot about us....I'll be placing my order shortly...
Nope we have will never forget our supporters because with out you guys we would not be here. That's why I keep on top of our suppliers to provide the best quality for a lower price
How do I go about ordering this?
Hi,
You can call us 561.214.4879 or you can send us a pm and we can call you.
THX, Jim
