Help!! Heater hose leaking!!!
Old Mar 26, 2005 | 10:58 PM
JaxCamaroGuy's Avatar
this hose is composed of rubber and metal and weird compression fittings, its leaking where the hose comes out of the water pump then to a large peice of pipe, i beleive called a restrictor, its leaking from one of those fittings, what can i do? can i just replace the rubber part of the hose?
Old Mar 27, 2005 | 09:12 PM
crasher88's Avatar
Re: Help!! Heater hose leaking!!!
no if the heater hose is leaking on a performed manufactured part like on our cars you will have to completely replace the whole hose assembly.
Old Mar 27, 2005 | 10:04 PM
i took a dremel tool and cut off those crimp on fittings that connected the rubber hose in the heater core valve and replaced the rubber hose and used 2 hose clamps to put it back on, works good so far, no leaks @ all
Magenta_Hearts
Mar 29, 2017 08:54 PM
dalynchmob
Feb 19, 2015 07:20 PM
Jlo
Feb 3, 2015 09:41 PM
crazypurgatory
Jan 12, 2015 10:45 PM
pologreen97z
Dec 2, 2014 10:42 AM
