D 0r Od
Old Mar 4, 2005 | 02:58 PM
camarobiatch
Guest
Posts: n/a
D 0r Od
Was wondering which gear people are driving in in their camaros. I always go between drive and overdrive depending on the trip. What are you guys running in ? Should I just run in overdrive all the time or what? Just trying to find out what's safer for the tranny if it makes a difference..thanks!
Old Mar 4, 2005 | 03:13 PM
Distephano's Avatar
Re: D 0r Od
Drive it in overdrive.
Its not going to be any worse for the tranny either way. If you only drive it in D, that like driving a 5 speed car, and only using the first 4 gears. Its better for gas milelage and lets your engine run at a lower RPM.
On a side note, the only reason I clicked this thread is because I had NO idea what the title was trying to say.
Old Mar 4, 2005 | 03:24 PM
Black94Camaro's Avatar
Re: D 0r Od
Overdrive bro... Saves gas and lower RPM like he said above. Sounds meaner to when u cruise at 1500RPM in 4th gear OD with the FLOWMASTERS! Now if you feel racey along with another fellow at a stoplight put it in Drive
Old Mar 4, 2005 | 09:53 PM
strongbad's Avatar
Re: D 0r Od
the only time i shift into drive is when im about to accelerate really quick or else i keep it in overdrive
Old Mar 6, 2005 | 10:28 PM
camarobiatch
Guest
Posts: n/a
Re: D 0r Od
Thanks for the feedback. Just one thing I'm not a bro !! I have t*ts !! Hence the signature. lol...............
Old Mar 6, 2005 | 10:32 PM
Re: D 0r Od
whoops my bad sorry girl
Old Mar 6, 2005 | 10:35 PM
camarobiatch
Guest
Posts: n/a
Re: D 0r Od
It's cool .. I can still probably outdrive 9 out of 10 guys !!!
Old Mar 7, 2005 | 04:03 PM
Chrisz24's Avatar
Re: D 0r Od
I only use Regular D (3rd gear) when I'm on steep hills and want an engine brake.
Old Mar 9, 2005 | 12:35 PM
camaros_4_lfe's Avatar
Re: D 0r Od
i use D for 99% of my city commute tranny shifts allot less etc.. any type of driving over 45 steady then i use OD
Old Mar 9, 2005 | 02:32 PM
Tru2Chevy's Avatar
Re: D 0r Od
Actually, if you leave it in D and not OD you will only being using the first 3 gears. the 700R4/4L60/4L60e is a 4 speed automatic. Third gear is 1:1 and 4th is the overdrive gear.
- Justin
Old Mar 9, 2005 | 07:15 PM
Distephano's Avatar
Re: D 0r Od
- Justin
lol, yeah I know. I was just making the analogy. 5 speed came to mind first, because thats what I drive.
Old Mar 14, 2005 | 11:24 AM
Vega's Avatar
Re: D 0r Od
That is the proper way of using it.
Old Mar 14, 2005 | 12:28 PM
camarobiatch
Guest
Posts: n/a
Re: D 0r Od
that's what I figuered. that is how I drive
