2 questions from a new owner
I just bought this '96 3800 AT, and below the lighter there's a switch that says 2nd gear start, what is it? Also, I just bought a replacement dimmer switch for the headlights, how do I get to the old one?
Re: 2 questions from a new owner
Actually when you turn this mode on (button lightens) from stop your tranny starts shifting from second gear. Try turning it on and you feel what I mean. It's supposed to be for slippery conditions or something, but I can't find it useful.
the 94 / 96 interior is identical. to get to the dimmer switch, you have to remove : the lower kickpanel under the drivers side, the dashpanel (above the cluster -- large flat piece of plastic, be extra careful not to break the heater vent (its very easy to do), and the cluster housing itself. (cluster housing = the piece of plastic that is around the guages / over the steering wheel / in front of the whole dimmer/lights/everthing switch.)
good luck with it and just be careful. only took me like an hour or so to get mine off.
uhhh...in the camaro? are you talking about the headlights or interior lights.
guess i was thinking interior (havent heard the headlight switch referred to as a "dimmer")
