Head cooling line replacement alternatives?
I'm finishing up a 383 build and was thinking about getting rid of those stock steel tubes running from the heads to the radiator (return lines). They are kind of a biatch to get on and my banjo bolt gaskets are shot. I believe there could be an easier alternative. What about just using a quality braided hose with an elbow on drivers head and a t on passenger? Anyone done this? Thanks for any ideas.
Re: Head cooling line replacement alternatives?
I have a set of braided lines for the crossover tube. I had them made to length at a local fitting shop. 90 degree elbow on driver's side, T on passenger side SS braided lines between and after the T and I routed it alongside the manifold. It worked fine.
