More Parts For Sale
More Parts For Sale
As you guys know I keep quite abit of hardcore stuff around. Got some more stuff to move. If you have any questions or want pictures just let me know.
Fresh Fully Prepped LT1 Block. Full Set of 5 Oliver Splayed Caps. Wet Sump Rear Cap, Bored to 4.030, Line Honed, Decked, O-Rings in Deck Surface, Notched for Stroker Crank to 3.875" and Virtually any rod combination. Block is Hardblock'd filled to the Plugs. $750
New (Installed but never run) Stef's Aluminum Oil Pan, w/ High Volume Pump and Pickup. Pan Has optional Stroker Notches. $300 ($420 through Summit new, have receipt)
New (Installed Never Run) ATI LT1 7.5" Balancer and Hub. $325
New LT1 SCE Copper Head Gasket Set $75
Custom 1 7/8"-2" MS Stepped LT1 F-Body Headers
Come with 3.5" Collectors. One 02 Sensor welded in collector. $500 ($950 New)
Fresh TH400 Fully Prepped by "Some guy in Kirkland"
. Reverse Pattern Transbrake Valve Body. Cast Aluminum Finned TCI Pan. New Hurst Ratchet Shifter, Has F-Body PCM friendly VSS Sensor already installed. $800
CSI Carbon Fiber TH400 Trans Shield $200 ($299 New)
F-Body OBDI PCM with LT1 Edit Program Expert Version locked to this PCM. $250
New Factoy SLP Firehawk Badging Grey in color. Bought these for my Hawk, never put em on, now its gone. Only available to Firehawk owners! Paid over $100 from SLP $80
I'm Open to some offers but lets keep em realistic guys. I'll leave this in the PNW until Sunday Night, and will then repost in the general Ads section everything that is unsold.
Kurtis Tamez
(509)961-2373
. Reverse Pattern Transbrake Valve Body. Cast Aluminum Finned TCI Pan. New Hurst Ratchet Shifter, Has F-Body PCM friendly VSS Sensor already installed. $800 CSI Carbon Fiber TH400 Trans Shield $200 ($299 New)
Kurtis Tamez
(509)961-2373
00WS6mike
Sep 13, 2002 10:37 PM
z28projects4ever
9
Jul 16, 2002 07:48 PM
