Crankshaft reluctor ring
Old Mar 12, 2004 | 12:07 AM
Built on Sin's Avatar
How do I remove the reluctor ring? It appears it is keyed?
Old Mar 12, 2004 | 12:12 AM
S.J.S.'s Avatar
all you do is pull it off brother. Nothings holding it on. The key is there but the hub is usually what holds it on there.
Old Mar 12, 2004 | 12:18 AM
97WS6SCharged's Avatar
Is that the ring in front of the crank gear that the crankshaft position sensor reads? Or am I thinking of something else?
Old Mar 12, 2004 | 02:04 AM
S.J.S.'s Avatar
yep thats the reluctor ring, unless he's thinking of something else.
Old Mar 12, 2004 | 02:10 AM
Just out of curiosity, does that need to be reinstalled if you do an OBD1 conversion and eliminate the CPS?
Old Mar 12, 2004 | 07:05 AM
RedTransAm21's Avatar
doesn't need to be reinstalled without a crank sensor, but if you don't put it back on you need a 93/94 style hub. it is a little longer than the 96/97 one because of that reluctor ring
Old Mar 12, 2004 | 07:12 AM
Ricardo's Avatar
You can also use a spacer to compensate for the absence of the reluctor ring.
Old Mar 12, 2004 | 08:39 PM
Ok, guess I'll just put mine back in then.
Old Mar 12, 2004 | 09:54 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
a double roller timing chain also gives it that "right amount of thickness" too
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
mmf_1013
Sep 12, 2015 08:56 PM
blaze309
Sep 8, 2015 05:27 PM
realistyc
Jul 28, 2015 07:32 PM
