What all do you need to make a 8.8 rearend work?
Old Mar 9, 2004 | 01:13 PM
97Camaro007's Avatar
I mean what all do you need to make a 8.8 ford rearend work in a camaro...I have a friend that wants to know and I don't have any idea.....He has a chance to get one for free and is wondering if it is worth it or not.....Thanks guys
Michael
Old Mar 9, 2004 | 09:40 PM
blksunshine's Avatar
hope this helps
http://extremechassis.com
Old Mar 10, 2004 | 01:38 AM
CamZ2811's Avatar
thanx for the link i did not know that they were doing the conv. here in DFW,
Im the one that was wondering about the 8.8 by the way i was at work and could not post.
looks like im going to get the compleat car for $250 its got lots of mods and i will be parting it out after i can get it torn down less the rearend of corse
so if any of you mustang folks interested in a parts list for the 93gt pm me or post e mail and i will get one out as soon as i can.
and any more info about the 8.8 conv. would be good
-brian
Old Mar 10, 2004 | 09:47 AM
fireman's Avatar
You have to weld your stock axle tubes to the 8.8 pumpkin.
You have to make a torque arm mount and weld it to the 8.8 pumpkin.
Your stock 28 spline axles will fit perfect in the 8.8 housing.
You need to heat the 8.8 pumpkin(cast iron I believe) with a torch before you weld to it or the welds won't hold as well.
I think thats it, as long as everything is measured and welded correctly.
Old Mar 10, 2004 | 09:51 PM
CamZ2811's Avatar
bad A$$ thanx
sound like i'll be running an 8.8
-brian
Old Mar 10, 2004 | 10:23 PM
94-3.4's Avatar
The axles do not fit perfect. Check out this link:
http://www.ls1tech.com/forums/showthread.php?t=138494
Old Mar 10, 2004 | 11:32 PM
n20ta2's Avatar
He was talking about the axle tubes not fitting in that post not the axles as they will slide right in.
InfernalVortex
Jan 17, 2015 09:35 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
siguy
Nov 27, 2014 10:07 AM
