?rwhp gains of Jett Hott Coated LTs over SLP shorites for '96Z
Old Mar 8, 2004 | 12:11 PM
Showme's Avatar
First of All Fellas,
I missed the hell out of this board. I caught a computer virus or something that put me out of commission for almost 2 months.
Anyway, during that time...I purchased a set of coated Jett hott LTs w/emmissions. I purchased a 3" noncoated custom y-pipe off a member of this board. The Y-pipe has 2 built in highflow cats. I'm trying to figure out how much of a gain should I expect. I called many speedshops around town and in the GM High-tech magazines and noone could give a definate answer. Either way, I'll tell all once I get them in and redyno the car later this year.
Current Mods are in the Siq.
Tim
Old Mar 8, 2004 | 01:23 PM
Showme's Avatar
25 views and not one single reply.....Hmmmmmmmmm
Old Mar 8, 2004 | 01:29 PM
Botch's Avatar
Should help, I would think they will compliment your mods well. I would be guessing but I'd say 15-20hp. Make sure you match the flanges on the headers to the heads or you will loose some power. I took .125" off in places on mine to match them to the 1406 gasket that the heads were ported to.
Old Mar 8, 2004 | 01:36 PM
GREGG 97Z's Avatar
Did you have SLP dual cat headers or single cats? Not sure what you meant by shorties since you have a 96.
Old Mar 8, 2004 | 02:04 PM
Cmr0z28's Avatar
I highly doubt they'll make more top-end HP, since the primary tube size is the same, but the long tubes will make more low end torque and that's about it.
Old Mar 8, 2004 | 02:09 PM
HesterZ28's Avatar
I disagree, I think you will free up about 15 high rpm hp
Old Mar 8, 2004 | 07:03 PM
RealQuick's Avatar
11rwhp/15rwtq. Bank on it
Old Mar 8, 2004 | 11:31 PM
Showme's Avatar
Hey,
Just getting in from work...
Thanks for the replies.
I have the SLP dual cat headers.
Only 11 rwhp/15rwtq. I would not have gotten them for that gain, but I've come too far to turn back
Nonetheless, I'll keep you all posted
Tim.
Old Mar 9, 2004 | 09:20 AM
RealQuick's Avatar
Originally posted by Showme
Hey,
Tim.
You may pick up more. I had the single cat headers, and they are the best shorties on the market.
Old Mar 9, 2004 | 10:51 AM
GREGG 97Z's Avatar
I would expect some big gains in tq and hp going from SLP d/c's to LT's, probably biggest gain will be in tq. I had the d/c's for a while (never installed them) they were not a well designed header to say the least. It's hard to say exactly how much you will pick up, I'll guess 15rwhp 20rwtq.
Old Mar 9, 2004 | 11:35 AM
RealQuick's Avatar
By the way, my numbers were peak numbers that I was guessing. You'll pickup more torque at lower rpms, but I think the peak will be where I said.
Old Mar 9, 2004 | 11:47 AM
GREGG 97Z's Avatar
So the gains you listed where going from SLP single cats to LT's? I'm curious cause I have the single cat SLP's and thought about going to LT's eventually. This guy should pick up a lot from SLP dc's over to LT's, there's no comparing the design of the two.
Old Mar 9, 2004 | 12:08 PM
RealQuick's Avatar
The way I figure it is this, Lloyd is pretty consistent and his heads with XE230/236 usually net in the mid 380's rwhp with mid 350's rwtq. Thats how I came up with his numbers Its all a guess. There is more to gain when going from dual cat headers to LT's versus the single cats to LT's.
Queens94z28
Sep 20, 2015 08:45 PM
KYWes
Aug 10, 2015 07:03 PM
Jlo
Jul 29, 2015 03:52 PM
realistyc
Jul 28, 2015 07:32 PM
