Best silicon for LT1 intake manifold
Im about to do the intake gaskets on my brothers 95 Z whats the best kind of silicon to use? I was thinking the Gray RTV? Also anyone got some insructions on doin this to make it easier.
Thanks in advance
Thanks in advance
I like using the cheese can silicone's uslualy comes in black, there is another product called the right stuff witch is actualy my favorate for installing chevy intakes and gaskets. it is a rubber based gasket maker, it's realy sicky so it keeps the intake gaskets in place much better than silicones, and it also comes in a cheese can type dispenser.
you dont NEED to have silicone on the gaskets, mostly its to help hold the gaskets in place for install and on some vehicle were the gasket serface is slightly pitted or has been damaged by incorrect gasket removal the silicone would help seal.
GM makes some good stuff. About $15 for a tube. It's real dark, pretty much black in color. Stuff starts to get real REAL sticky in about 30 seconds. Works damn good though.
Don't ask me for a link because I have no idea.
Originally posted by Dan_gearhead
http://www.projecttransam.com/projects2.asp
http://www.geocities.com/MotorCity/Downs/4013/ol.html
Don't beleive a word of what is said in that thing as far as how an oil leak starts.
The best sealant to use is either Ultra Copper, Ultra Black or the GM sealant. And retorque the intake bolts after a few heat cycles.
Oh cripes.. that ken collings page is still floating around? LMAO
Do not use sandpaper to clean surfaces like mentioned in the ridiculous article.
Do not under any circumstances use rtv on the intake gaskets
You do not need to let the car sit 24 hours for cure time. Put it back together and drive it..
GM sealant is all that I use on intake manifolds.
Oh yeah..
Exactly....
Ugh... SANDPAPER on your block???? C'mon now!
You do not need to let the car sit 24 hours for sure time. Put it back together and drive it..
I'm not sure why I started using ultra copper on header gaskets, but all I know is I have never had a header gasket leak with a thin coat of Ultra copper on the gaskets. on most stock SBC manifolds I do not use gaskets at all, just ultra copper.
Dude start using some nice felpro header gaskets and you wont have to deal with that crap. That's gotta be messy and time consuming as hell trying to goop all that crap on those headers...
