Still getting black smoke...
I had posted a while back that my car was blowing out alot of black carbony smoke. I always get build up on my bumper and can see it in my rear veiw sometimes. I have done the sea-foam flush. Also my car back-fires every now and then as well. Not getting any codes either. (OBDI). Maybe it's a bad O2 or something? I know a little is normal but this seems like too much. Any help will be very appreciated. Thanks!
Originally posted by aintno6
What have you tried doing so far?
I would suggest changing plugs and wires, if you havent allready, and what grade and brand gas are you runing?
I try different gases to see. Mainly use 93 oct from Chevron and Exxon. I replace the fuel filters regularly as well.
So could that cause my "back firing" flop sound? I think I have an exhaust leak around the y pipe MAYBE. Thats ok because I am ordering a set of Macs and Y pipe tomorrow from Jet Hot. What brand O2's are you guys using? Thanks for the replies guys.
if its black smoke,its definately fuel related.1 more vote for o2 sensors
.Also,just to be clear ARE YOU SURE you wired alll the plug wires to the right cylinder?i know its a dumbe question to a certain extent,but no use spendin money when the fix might be free!! good luck
Before you start throwing parts at it, why don't you scan it and see what the sensors are reading? All of them. There are several things that could make your car run rich. The most common 2 I can think of this early in the morning is a hole in the FPR diaphragm. If so the vac line would be wet. The other is a sticky injector.
One other I just remembered is a vacuum leak would cause the mixture to appear lean at the O2's and the PCM would try to richen the mixture.
Just a friendly $.02
Thanks for the suggestions guys. I am going to have it scanned again before I do anything. All of the plug wires are in the right place. Maybe I can get it scanned this weekend. I'll post an update.
