wiring w/led for electric water pump
I have used a relay and the orange wire from the under hood fuse box to turn the pump on i was trying to use a led (blue) wired up between the fuse and the water pump so i will know if the pump is on when the led is on. if the led is a 5 volt do i need to use any resistors or diode if so what size? i have a diagrahm from akm cables but it does not say anything about resistors.can anyone help
thanks!
thanks!
I bought 2 LEDs with resistors built into them from radio shack for like 2 bucks. One (green) is hooked to the ground line, and the other (red) is hooked to power. If either light fails to light then I know I have a problem, and I can get a idea of which line to chase by the color of the light.
Q
Q
I bought a blue led from radio shack (5 volt/30ma/300mcd) i hooked it up and it came on but now it will not come on even if i hook it directly to the battery i think maybe it has blown. 5mm (part# 276-311) is what i used. thanks
stockssn2o
May 25, 2015 08:54 AM
Henson071
May 4, 2015 12:23 PM
