Can you over tighten oil filter?
I just changed my oil and now I have a small leak that is dripping from the front of the tranny. I checked the back of the manifold and it seems fine. I do remember tightening the filter pretty good, just curious if the seal may have messed up and that is causing the leak. Thank you for any help!
You can just rechange the filter if the gasket bulged, if not I would just look at it while the car is running (all 4 wheels in the air , and run it to see if it leaks any. But if it is bulging I would replace it, yo umay get 2 or 2000 miles and it blows all your oil on the ground.
Another thing to look out for is if you over tighten the filter, when you go to change it out, often times you can loosen the oil cooler as well and start a leak. I had this happen once and had to pull the whole cooler out to remove the filter. Very dirty job at best
If you have an oil coller, just remember to retighten the large nut on it before putting on a new filter. This maybe where your oil lieak is coming from.
http://community.webshots.com/album/33786390mmhudJ?888
Jul 4, 2005 05:00 PM
