Autocross and Road Racing Technique There is more to life than a straight line
How do you know when and how much to adjust Koni SA shocks?
Old Nov 25, 2003 | 06:35 PM
sikz28's Avatar
I just recieved my Koni SA front shocks and my ST 35mm sway bar. I am just waiting on the Bilstien rears to install them. How do I know if I should adjust them. When I ordered them I was told to set the fronts 1.5 turns from full soft to start with. Does this sound like a good starting point?
Old Nov 25, 2003 | 06:55 PM
Sam Strano's Avatar
Um, that's interesting..... The fronts don't have the ability to actually make a "turn" because of the window the Koni uses to adjust them. I always run them @ or above half-way to full hard. Usually I go to full hard and back them off about 4 sweeps, which *if* there were turns would be, in theory, around 1.5 up from full soft................ Sometimes I tell folks that, just so they have an understanding of the window and the sweeps vs. the **** and turns utilized on the rear Koni's.
Old Nov 25, 2003 | 08:47 PM
Jeff94TA's Avatar
On mine there is about 10 sweeps from full soft to full hard. I guess a sweep would be about 1/3 of a turn so 1.5 turns sounds about right. I usually run about in the middle on the street and two to three sweeps more for competition.
Old Nov 26, 2003 | 07:32 AM
bruecksteve's Avatar
I run mine a little firmer (I know, I'm went against Sam's advice ). Maybe I'll try backing off mine a little next season.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
