Autocross and Road Racing Technique There is more to life than a straight line
best LCA for handling on LT1 fbody
Old Nov 20, 2003 | 02:37 PM
pillagenburn's Avatar
just wondering what kind of LCA would be best for handling purposes on a LT1 fbody. I guess not all LCA's are good?
thanks!
Old Nov 20, 2003 | 03:38 PM
LPEdave's Avatar
The best handling will be one with rod ends. I'm not convinced you need rod ends on both ends of the LCA, you should be able to use poly on one end without much or any issue.
After that, it's just a matter of finding an LCA with good quality rod ends on it.
Dave
Old Nov 21, 2003 | 02:38 PM
mitchntx's Avatar
I have G2 poly/rod LCAs from LG Motorsports.
Been on for almost 2 years, seen lots of hiway and track miles and they are as tight as the day I bought them. And are almost as quiet as stock.
Old Nov 21, 2003 | 08:14 PM
Lady in Nomex's Avatar
I run the Global Wests on both my cars in the sigs. These are double rod ended. I also suggest you take a look at the Unbalanced Engineering versions. Their cars have been winning a lot of races this year!
meissen
Jun 1, 2015 07:59 AM
D1SC383LT4
Jan 26, 2015 01:41 PM
