Sister Is An Idiot!!!!!locked Keys In Car Heelllppp!!!!!
Old Oct 8, 2003 | 10:24 PM
jasons93z's Avatar
Angry Sister Is An Idiot!!!!!locked Keys In Car Heelllppp!!!!!
I hate my sister, i let her drive my car and what does she do, lock the keys in them. Is there anyway to get in, besides breaking the window I have keyless entry if that helps. I have a lot of sheet metal so i could make a jimmy stick, but im not sure if u can jimmy these cars. PLZ HELP!!!!!!!!!!! BEFORE I KILL MY SISTER
Old Oct 8, 2003 | 10:26 PM
Seal's Avatar
i've slim jimmed MANY cars, and i've done tons of fbodies... so yes its possible, if you know how to, it'll take u 5-10 mins (its a bit harder with power locks)
NewbieWar's Avatar
donno really, if u have a spare door key someplace else... if u call AAA they can make u a key on the spot for ur door... or they can break in for u w/ causing problems
other then that i donno what to tell u i donno much about the keyless entry
Old Oct 8, 2003 | 10:28 PM
jasons93z's Avatar
How do u exatcly do it. Ive never done it before
madwolf's Avatar
My driver side window was a little sloppy and I could detach it from the weatherstrip just enough to fit a pool cue through it and push the unlock button. Something thinner will work better but that's the only thing I had and could think of at the time.
Old Oct 8, 2003 | 10:34 PM
jasons93z's Avatar
Already tried that, my lock thing is loose so it just moves around, this sucks.
Old Oct 8, 2003 | 10:37 PM
NewbieWar's Avatar
try the other side
madwolf's Avatar
How about on the other side?
EDIT: NewbieWar beat me to it.
Old Oct 8, 2003 | 10:38 PM
chasmanz28's Avatar
do you have AAA or some kind of car service
Old Oct 8, 2003 | 10:44 PM
NiteRider's Avatar
I always pull my window out and slide the hand in. Works great, gives a bit of shock to the window for a few days when your opening and closing it but it passes.
Old Oct 8, 2003 | 11:11 PM
HM Murdock's Avatar
Pull the window out and take off the T-top, if you leave them unlocked...My sis had to do thiS with her(my old) 95 z28.
Old Oct 9, 2003 | 01:07 AM
Fastbird93's Avatar
Here's another vote for pulling the window out and just slipping your arm in. It won't break, trust me, I don't have very skinny arms.
Old Oct 9, 2003 | 01:26 AM
Johnnynsac's Avatar
Well this is what I did in order to get my locked car open.
Stretch a metal coat hanger out. Stick in your, oh, thats another story.
Ok, stick it in between the window and the rubber. You might have to grab and pull down the window with your hand just a tiny bit for the coat hanger has room to move around and just aim for the lock on the door.
Old Oct 9, 2003 | 01:47 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
use a coat hanger (or something thicker.. I have used an antena before!!) pull back the glass a little, and use it to pull on the luck/unlock lever.. pull it forward.
I bent an antenna with a slight bow to it, and then bent the end about 140degrees like a hook.. used that hook to snag the lock lever.
done this MANY times between my car and all the fbody friends I have.. put it this way, with ZERO tools I can break into an fbody in about 30seconds
Old Oct 9, 2003 | 02:21 AM
drewstealth's Avatar
I remember a guy on here saying to unscrew your antenna and pull the window back some and push the button. You can pull the window pretty far back.
ro2207
Dec 4, 2014 06:18 PM
ChrisFrez
Nov 30, 2014 08:41 AM
USAirman93
Nov 24, 2014 03:37 PM
x7x7
Aug 15, 2002 06:49 PM
