a little plastic ring behind the waterpump. do i really need it??
While I am not sure exactly the part that he is refering to, I am under the asumption that the cam retaining plate that bolts to the block is responsible for limiting cam "walk". I have never heard of part of the waterpump drive system being responsible for this. Of course as always I may be missing something here.
There is no 'spacer' involved in the water pump drive...
Also it doesn't run DIRECTLY off the cam.. there's a 'drive gear'[inside the block, runs off the cam, located above it] that has a shaft that protrudes thru the timing cover...
That drive shaft, and also the water pump shaft [both'male'] have O'ring seals that go in a groove cut in the splined portion...
Then there's the 'water pump coupling' that connects the two..
There is no spacer in there...
I think you are talking about one of the 'O'rings' [that tend to harden, become brittle, and break/fall off?]
Also, I believe the purpose of them to be to keep the drive coupling stable to help prevent it from tearing up the seals...
Can you run without it?
I would say it's OK for a while, but I would get new ones in there soon..[there are 2 as explained above] GM p/n 12553792....
Cost? pennies really, but of course you have to remove that water pump to DO em..
While we are on the subject of w/p drives. I am instaling a CSI pump here shortly & was planning on leaving the drive system in place, just remove the coupling, for now until I change cams here in a few weeks. Then I am going to disguard the whole w/p drive system & seal the hole in the timing cover. I am assuming that this will cause no problems, am I correct?
Far as I know there is NO 'ring' BEHIND the wp coupling[the 2 I describe above are INSIDE that coupling, they go on the ends of the male shafts the 'coupling connects?
Maybe it's a piece of your timing cover water pump drive shaft seal going bad?
That's all I can think of?
I may have a pic I can email you of that area?[water pump drive shaft/timing cover]
Charlie
EDIT OK .. I looked at pic.. while it doesn't go at the END of the shafts, they're still inside [the ends of the coupling] when assembled...
Charlie
hmmm. because in my case. as soon as i opened my old waterpump, there was a ring hanging on to the timing cover shaft. is that the one, mind you that this ring size can barely fit your pinky finger....thanks
I'd say that's a piece of the WP timing cover seal?
When the 'O'rings' get brittle they break into pieces[in other words you wouldn't GET them off to put onto your finger? They break in pieces like brittle plastic when they dry out..]
Also see above edit re: location of 'O'rings'
OK the key would be is the diameter of what you are talking of the diameter of the WP COUPLING[the outer dia? that would be a piece of the TC seal failing] or the smaller diameter WP drive shaft 'grooves'[that would be the 'Orings']
Originally posted by TMDZ28
i think we are talking about the orings here...where can i get them? are they expensive?? thanks a lot man
GM p/n 12553792.... from a GM dealer
CHEAP[like less than a buk each, probably a buk for the 2]
how much is one of that little ring cost?? thanks
