About to put in a new cam, do I have everything I need?
Alrighty, I blew my head gasket, so I have to tear my heads off now. I figure, why not put in a new cam and valve train while I'm at it. Here is what I have for the install.
Cam
Lifters
RR's
V. Springs
Retainers
O. Ring Valve Seals
Gasket kit (valve cover, ect.)
Head Gasket
Anything else you think I need/should put in while I'm at it. I don't have enough $$ to P&P the heads. Thanks alot guys. Noah
Cam
Lifters
RR's
V. Springs
Retainers
O. Ring Valve Seals
Head Gasket
Re: About to put in a new cam, do I have everything I need?
Originally posted by npaulseth
Cam x 2
Cam x 2
You have two cams??You'll need, intake manifold to head gasket, exhaust manifold gaskets, timing cover gasket, some RTV sealant for the front and back of the intake manifold.
Might want to put in another timing set if you have the $$.
John
Brandon Wittmer
Dec 20, 2014 09:51 PM
