Radio stays on all the time?
Old May 8, 2003 | 08:27 PM
95Bird's Avatar
When I turn the car off power keeps going to the radio. Not a real big problem because I just hit my kill switch. What could be doing this. Think the ignition is going bad?
Old May 8, 2003 | 08:34 PM
Blk94Z28LT1's Avatar
does it cut off when you open the door?
Old May 8, 2003 | 08:35 PM
Rodrigues's Avatar
Uhh, problem? Thats normal It will shut off when you open the door. Its retained power accessories....
Old May 8, 2003 | 08:44 PM
Koors96Z's Avatar
haha yeah open your door and see if it goes off, if it's still on then you may have a problem.
Old May 8, 2003 | 08:55 PM
95Bird's Avatar
it stayed on all day today. No matter what I did..just went out and checked it again..went off this time when I open the door like always. Today I had to shut off my cut off switch to kill it..weird. Sometimes my headlights won't pop up either untill I turn them off and back on..I think I got some electrical grimlins going on.
By the way..I knew that it was suppose to stay on untill you open the door...heheheh.
Old May 9, 2003 | 01:16 AM
96 WS6's Avatar
if you have an aftermarket deck... there are two +12v wires, one for accessory and one for constant power (memory etc.) If they are crossed it would stay on. Check the wiring.
Old May 9, 2003 | 01:20 AM
Skull Leader's Avatar
Exclamation
If you listen to alot of devil worship metal that's so popular amongst the F-body crowd, that could have something to do with your ailments. Seek holy water immediatly.
Old May 9, 2003 | 01:22 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
sounds like you need a seonce...
Old May 9, 2003 | 01:36 AM
chasmanz28's Avatar
lol too much OZZY
Airplanedoc
Feb 1, 2015 07:14 PM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
Snoman73
Nov 17, 2014 07:22 PM
