Return To Forum After A Post???
What do you do to get back to the forum after you write a post or reply ?? if i use the back button , it keeps sending me in a loop !!! MEL:confused: :confused: :confused:
I use 'back' button in rather fast succession...not slow, fast enough page doesn't really 'load' .. works for me..:cool:
you really shouldn't have to do that !!! a MODERATOR should answer this question asap if they saw it!!!!MEL:confused:
First of all this is the Parts Wanted section. I'll move it to the proper section. Second of all, can you please explain your problem a little bit more?
he's talking about after you make a post and it says "Returning you to the post, please wait". If you hit back after that, it will go to that screen again, which will promptly reload the post again, hence the loop he's talking about.
that is not the proper way to do it though. even if it worked good, it still woudn't update the thread icons, or refresh the topic page. Just go down near the bottom of the page, and to the left you see a selection box that has the section you're in displayed in it, and to the left of it is a red GO button. Just always use that button to return to the topic page. |
At the top of the screen right below the logo, you can click on one of three things after replying to a post: CamaroZ28.Com Message Board > Community > Appropriate forum name here. Just click on the forum name again.
ANEURISM has the problem 100% corect !!! but if i'm not mistaken, if you're on page 10 & you hit the GO button, you go back to page 1, not the post you were on !!!if you hit the thread before or thread after button, it still keeps you in that same loop when you hit the back button again !!!! MEL:confused:
What browser do you use?
i'm using AOL MEL:confused:
Originally posted by 89 IROC DROP TOP i'm using AOL MEL:confused: |
Originally posted by 89 IROC DROP TOP ANEURISM has the problem 100% corect !!! but if i'm not mistaken, if you're on page 10 & you hit the GO button, you go back to page 1, not the post you were on !!!if you hit the thread before or thread after button, it still keeps you in that same loop when you hit the back button again !!!! MEL:confused: Just for convienence, I will post his message: At the top of the screen right below the logo, you can click on one of three things after replying to a post: CamaroZ28.Com Message Board > Community > Appropriate forum name here. Just click on the forum name again. |
