1995 Camaro Theft Deterrent Relay Location
Old 05-16-2019, 12:38 PM
zlighting's Avatar
Does anyone have an actual photo of Theft Deterrent Relay location?
I'm tracing an intermittent ("click, click, click") ignition starting issue and need to locate relay for further testing.
Thanks!
zlighting is offline
Old 05-16-2019, 12:55 PM
peterpar's Avatar
Re: 1995 Camaro Theft Deterrent Relay Location
peterpar is offline
Old 05-16-2019, 01:31 PM
The relay (not the same as TDM) is wired into path between the ignition switch and the starter, per Shoebox:
4th Gen LT1 F-Body Tech-PassKey/VATS
Per this diagram, it in a yellow wire, between splice S223 and connector C210:
http://shbox.com/1/starter_charging_95.jpg
Injuneer is offline
Old 05-16-2019, 02:33 PM
peterpar's Avatar
My apologizes Fred, I assumed the relay was part of the module. Here's the correct location.
peterpar is offline
Old 05-16-2019, 04:55 PM
No problem...... we need all the help we can get on this site. Not a lot of knowledgeable people left, and your answers are always extremely helpful!
Injuneer is offline
Old 05-18-2019, 06:33 PM
zlighting's Avatar
Thanks guys, I did manage to locate the relay today and ruled out any wiring issues up to the harness, but tomorrow will jumper test S223 and connector C210.
I'm now focusing on locating any lose wiring connections from the ignition switch to my alarm/remote starter, and the starter kill switch which I installed 20 years ago.
The intermittent click first started using the remote starter only, and during the years became worse; however, earlier today I touched certain wires and think I'm close to fixing the problem.
A certified GM mechanic told me years ago, the dealership won't troubleshoot anything until vehicle's alarm/remote starter has first been removed and is most always the cause of such problems.
Since I'm tinkering on my spare time, I'll post the final outcome when I'm done.
Thanks again!
spm4520
02-11-2023 06:33 PM
loverboy95ta
12-04-2008 09:28 PM
fraser11
3rd Gen / L98 Engine Tech
02-01-2007 01:17 AM
unTAmedLS1
07-17-2005 07:45 AM
ssdungeon
05-14-2003 04:08 PM
Quick Reply: 1995 Camaro Theft Deterrent Relay Location
