Optispark identification
Old 12-17-2018, 06:14 PM
Jdblood202's Avatar
Hey guys, I recently picked up a LT1 from a 1994 Chevy Caprice to have as a spare LT1 block, I have a question about the optispark. Does the tube that goes from the opti to the air intake mean that it's a vented opti? Also, other than installing and testing it, is there a way to check and see if its working properly? Thanks guys.
Jdblood202 is offline
Old 12-17-2018, 07:47 PM
sbs
sbs's Avatar
Re: Optispark identification
Take the cap off and inspect for rust.
Some people have done bench testing, but if it's not rusty inside you're probably good to go.
sbs is offline
Old 12-17-2018, 07:55 PM
Jdblood202's Avatar
Ok, where can I get the right torx socket to get the cover off?
Old 12-17-2018, 08:27 PM
pontiacstogo's Avatar
It's an E-4 torx. You can also use one of the screws from the throttle body cover in a pinch. Lot's of threads (ha!) on the subject - here's one;
https://www.camaroz28.com/forums/lt1...ispark-474865/
pontiacstogo is offline
Old 12-17-2018, 08:34 PM
Jdblood202's Avatar
Awesome, thanks!
Old 12-17-2018, 09:04 PM
Take the harness connector off your current installed Opti. Plug it into the spare Opti, and connect a ground from the Opti metal casing to the block. Turn the key to “run”. Hook a volt meter between the red/black wire and the pink/black wire. Slowly rotate the drive. In one full revolution of the distributor drive, you should see 8 slightly uneven spaced, variable length pulses where the voltage jumps from 0 volts to 5 volts. That would confirm the low resolution signal.
Now measure the voltage between the purple/white (or light blue/black) wire andthe pink/black wire. Rotate the drive slowly. In one full rev of the drive, there will be 360 even spaced, equal length spikes from 0 volts to 5 volts. Don’t try to count them, just observe it appears to match what is described. That would confirm the high resolution signal.
Note that the optical module may fail intermittently when it heat soaks under actual engine heat. Difficult to test, unless on a bench.
Schematic from Shoebox
http://shbox.com/1/95_ign_system_schematic.jpg
Injuneer is online now
Old 12-17-2018, 09:08 PM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
To answer your first question, it is the vented version.
GaryDoug is offline
Old 12-17-2018, 09:20 PM
And yes, it’s a vented Opti in the photo. In addition to the two hose connections, it has the cam dowel pin drive mechanism used in the vented 95-97 F-Body LT1. The Caprice got the vented Opti in 94. The unvented 93/94 unit has a different splined shaft drive.
From Shoebox:
93/94
http://shbox.com/1/93-94_opti.jpg
95-97
http://shbox.com/1/opti_back.jpg
lightskindwonder
12-07-2012 11:06 PM
96m6lt1
05-25-2008 08:34 PM
30696bird
05-09-2008 08:33 PM
z28-06
02-20-2007 12:42 PM
davidarel
11-30-2006 11:55 AM
Quick Reply: Optispark identification
