Another LT Owner, Minnesota
Hi, I just joined this group. I have a nice ‘94 Buick RoadMaster station wagon. It has the LT1 motor 265 hp. So a low hp one. The car only has 110 K on it and has not seen a winter.
ive already had minor issue with the OPTI Spark. I had this replaced with a new old stock Delco unit. The oil seal behind it failed and filled the OS with oil. It does have the vacuum purge hose and that was rotted and plugged. Also installed a new water pump and spark plugs. Shortly after I had to replace the left cat. Converter.
It runs nice niw but has 2 issues that I’ll post separately.
Byron
Byron
