Audio and window
Old 08-16-2018, 12:14 PM
Thedog's Avatar
Audio and window
Got a 1994 z28 camaro windows and stereo go out and come back on happen twice already
Thedog is offline
Old 08-16-2018, 01:22 PM
DrewHMS97SS's Avatar
Re: Audio and window
Are you saying that when the speaker stops working, that the power windows also don't work? If so, it sounds like you have a wiring issue between the car and the door.
DrewHMS97SS is offline
Old 08-16-2018, 01:31 PM
Thedog's Avatar
No the radio the system and the power windows go off than dont work then radio and windows come back on working
Thedog is offline
Old 08-16-2018, 01:33 PM
Response is for a 93-95....
The radio and power windows are supplied 12 volt power by the Retained Accessory Power (RAP) module. Here's some info on the module, courtesy of Shoebox:
4th Gen LT1 F-body Tech Articles
http://shbox.com/1/express_down1.jpg
http://shbox.com/1/rap_schematic.jpg
Sounds like a loose connector, or an intermittent problem with the circuit board in the RAP module.
Injuneer is offline
Old 08-16-2018, 03:24 PM
Thedog's Avatar
Okay thanks going to check that out
Thedog is offline
Old 08-16-2018, 10:43 PM
95LT4Z28's Avatar
had the exact same problem. it was the RAP module. if i moved the plug around the power to the radio and windows would go on and off. replaced the module and problem solved.
95LT4Z28 is offline
Old 08-23-2018, 04:22 PM
leon96z's Avatar
I had this problem. I took the body control module from under the passenger side of the dash and resoldered some pins. See this:
No problems since. Hope this helps you.
Leon
leon96z is offline
Old 08-23-2018, 08:05 PM
https://www.youtube.com/watch?v=VFTXuk3X94M
Leon
The thread starters 94 does not have a body control module.
Injuneer is offline
Old 08-29-2018, 11:30 AM
Thedog's Avatar
Does any part store have it or do I got to go to the dealership?
Thedog is offline
Old 08-29-2018, 01:11 PM
Probably find one on eBay. Or you could open yours up and see if you can see a problem with the circuit board - loose wire/solder, broken printed conductor, etc.
Injuneer is offline
95LT4Z28
11-02-2017 07:38 PM
OutlawPerforman
10-30-2017 05:40 PM
NORALTA
05-20-2007 01:34 PM
QuIcKA$$z28
09-29-2006 12:40 AM
Quick Reply: Audio and window
