Hi,new to site,can you help me out?
Old 05-31-2018, 08:05 PM
Speedy96's Avatar
Hi found two of these in my 96 lt1 oil pan and have no idea what they are or where they came from,any ideas?
Cylindrical,steel,look like roller bearings but from what?
Speedy96 is offline
Old 05-31-2018, 10:57 PM
Chimera96's Avatar
Re: Hi,new to site,can you help me out?
are those pieces of push rod?
Chimera96 is offline
Old 06-01-2018, 08:07 AM
94Z28LS1toLT1's Avatar
That's what I was gonna say too.
94Z28LS1toLT1 is offline
Old 06-01-2018, 10:45 AM
Chimera96's Avatar
can't tell in pic if those are hollow. If not, they are not pieces of PR
The relief pin in oil pump looks similar in size if it is solid. That is held in with a roll pin so quite unlikely that would come out...and there is only one of those in a oil pump
Old 06-01-2018, 11:57 AM
Shaft from a roller rocker tip roller?
Injuneer is offline
Old 06-01-2018, 06:10 PM
Speedy96's Avatar
It is solid,It's to small for push rods and those I checked when I did the valve seals. It doesn't have roller rockers, I'm gonna guess the oil pump pin. The other one is smaller than the one pictured. Thanks for all your input
Speedy96 is offline
Old 06-03-2018, 05:46 PM
Chimera96's Avatar
yeah I said because it is similar in size....but I believe the oil pump needs to have lower 1/2 unbolted for the roll pin to come out to even allow the pin to come out and there is only 1 pin so don't see it as coming from oil pump
injuneers note on RR end roller pins would be way more likely but you say the 2 pins are different sizes..
If you are not original owner to the motor in the car...who knows WTF got dropped into or left inside motor before you got the car. Good you found it before something went bang or boom....unless that is how you found it.
Old 06-07-2018, 04:06 PM
bw_hunter's Avatar
The sort of look like Camshaft/OPTIdrive pins. Maybe during an OPTI switchbthey got dropped into the pan...
bw_hunter is offline
Old 06-07-2018, 07:14 PM
Speedy96's Avatar
I have all the paper work on the car since 2001 and the opti spark has been changed three times already so I spose that's quite possible,thanks
Speedy96 is offline
Old 06-08-2018, 11:30 AM
Chimera96's Avatar
It would take someone to pull the pin from cam (not easily done at all) and that pin won't just fall out into the motor (timing cover) for it to then migrate down into the pan.....and twice. If it did fall into the motor on opti removal it would make MAJOR noise getting ground up in the timing gear/chain immediately on startup
I see way better odds winning the lottery than that happening
If P.O. had intake off maybe whatever the small metal pin is fell into intake valley from careless P.O.
Old 06-13-2018, 03:18 PM
Felix Sanchez's Avatar
Hi my name is felix and i have a 94 camaro and its getting hot on me. I changed out the water pump, the thermostat out but it leaks out of the coolent reservoir
Felix Sanchez is offline
Old 06-13-2018, 05:34 PM
You need to start your own new thread. You can’t hijack someone else’s thread on a totally unrelated subject.
The “new thread” button is top left, above the forum topic listing.
Injuneer is offline
Old 06-20-2018, 07:42 PM
bw_hunter's Avatar
You’re probably right. I did have the pin come off with the OPTI with my aftermarket cam. It fell right down into the timing cover and into the pan like it was on a mission. Not likely to happen two times though...
MikeGyver
10-05-2009 07:45 AM
slowZ
05-24-2008 07:56 PM
Harvey
04-03-2006 02:23 PM
Jeff95TA
01-11-2006 10:49 AM
blazingz28
10-27-2002 02:10 PM
Quick Reply: Hi,new to site,can you help me out?
