Engine Idle
Old 02-15-2018, 05:07 PM
DrewHMS97SS's Avatar
Engine Idle
Question: would a sticky IAC valve be the cause of idle speed changing? Most of the time the car idles at 7-800, but every now and then it will drop to 600ish. If I blip the gas it jumps back to the 7-800 mark.
If this is the case, should I just replace the IAC or is there something I can do with what's on the car?
DrewHMS97SS is offline
Old 02-15-2018, 08:33 PM
Re: Engine Idle
Does the RPM drop correspond to A/C cycling (if you still have A/C)?
Any chance the throttle blades are hanging up a bit, and suddenly releasing?
Shoebox's IAC Check:
http://shbox.com/1/iac2.jpg
Any access to a real time PCM scanner, which allow you to observe how the PCM responds to the RPM drop, with respect to IAC counts?
Injuneer is offline
Old 02-20-2018, 02:13 PM
Re: Engine Idle
I have an Actron scanner, I should be able to watch it from there. I have opened and closed the TB a number of times (hot and cold), and don't feel anything catching. No A/C on the car right now.
I will try to look at this over the weekend. Thank you Fred!
OnefstCamaroZ28
04-27-2004 09:18 PM
mikeRv6
03-10-2004 06:14 AM
2turboz28
03-01-2004 02:51 PM
teke184
01-12-2004 02:30 PM
Robert95z
05-08-2003 07:13 PM
Quick Reply: Engine Idle
