Vortech S-trim w/Aftercooler
Old 01-27-2018, 09:03 PM
Jason Short's Avatar
Complete Vortech S-trim supercharger package for 93-97 LT1 Camaro/Firebird. This setup has all of the needed upgrades to really make a potent and reliable package. This was just removed from a well running car 3 weeks ago and has not been sitting. The car made 610rwhp (396ci engine, 11psi) and was built with a significant amount of input from Jeff "LJ" Stevens and identical to his S-trim setup that went 9.9@139. To summarize: This combination works and is proven to make more power than a lot of larger superchargers.
- Vortech S-trim headunit (less than 1000 miles on rebuilt head)
- ASP 7" crank pulley
- Vortech 2.95" blower pulley (currently mounted)
- Vortech 3.125" blower pulley
- GM LT1 crank pulley/balancer machined to accept ASP pulley
- All mounting hardware (identified in correct location)
- Brad Brand solid intake tube
- Couplers/clamps
- Vortech main mounting brackets (upper and lower) with all hardware
- Gates belt
- Vortech tensioner and idle pulley
- Vortech Aftercooler (air-to-water)
- Upgraded "Mustang" ice tank
- All water lines/clamps
- Aftercooler water pump (less than 1000 miles)
- Air-to-air heat exchanger
- Oil feed line
- Oil return line
- K&N air filter
- Blower to Aftercooler piping
- Aftercooler to throttle body elbow piping
- Solid throttle body elbow
- Vortech bypass valve
- Vacuum lines
$2400
Jason Short is offline
Old 07-16-2018, 07:33 PM
Re: Vortech S-trim w/Aftercooler
Still available. This is a very powerful little setup. I also have a brand new Vortech Mondo bypass valve if someone is interested. 100% complete setup here.
Old 07-20-2018, 08:51 AM
d2harris's Avatar
PM Sent
d2harris is offline
Old 07-20-2018, 06:59 PM
d2harris's Avatar
Check PM
d2harris is offline
Old 07-20-2018, 08:50 PM
PM returned.
Old 07-21-2018, 07:32 AM
Sold to d2harrs, thanks!
bad95formula
08-11-2009 08:30 AM
Jason Short
08-30-2008 07:41 AM
Jason Short
08-06-2008 08:52 AM
Jason Short
06-30-2008 10:42 AM
Quick Reply: Vortech S-trim w/Aftercooler
