[Interior] 2013 camaro bcm help!!
I have a 2013 Camaro and recently some dude ran a red light and hit my car on the passenger side. i’m currently getting my exterior repaired but need to go somewhere else to get my interior fixed. my radio shoots out and it’s getting worse to the point i even turn off my radio and it still shoots out. my air conditioner will turn off and then come back on as well and the lights on my gauges will dim too. is it the BCM? and if so can you PLEASE tell me the location of it? i simply cannot find the BCM on my 2013 Camaro whatsoever. If it’s something else i all ears on to what the problem might be and how to fix it! please and thank y’all for those that reply !
Re: 2013 camaro bcm help!!
Some quick googling leads me to believe that the BCM in your car is under the driver side dash, above the accelerator pedal.
Find it, trace all wires, look for pinches, cuts in the insulation, damaged connectors, loose grounds, scorch marks, etc.
