1994 Formula Firebird street/strip
Old 10-03-2017, 02:53 PM
dougg01's Avatar
Smile 1994 Formula Firebird street/strip
Stalled project and need to move it. Asking $10k for the car. Negotiable.
1994 Pontiac Formula Firebird Street/Strip car that needs finished. Runs and drives.
Full set of factory wheels/tires go with it. Not currently tagged or insured. No exhaust. The car virtually never saw rain when it was on the road. Have a CC306 cam, Crane 10308 spring kit, and all gaskets and such that go with it.
Engine: 355ci Gen II LT1;GM LT4 Hot Cam;Comp R lifters and pushrods;Stainless 3/8 roller rockers with guideplates;Ported heads;AC-delete pulley;LT4 timing gear;ATI damper;Eagle H-beam rods;ARP fasteners;SRP pistons;Balanced;Melling pump;Hooker headers;BBK 58mm throttle body;Custom Tune
Drivetrain: (no runs or street time on all drivetrain)New Rossler TH350;Hurst ProStick shifter - forward pattern;New Precision 3500rpm nitrous-ready converter;New Denny's Driveshaft;New Moser 12-bolt, 3.73s w/ spool
Chassis/Suspension:stock front with ½ coil removed;10-pt cage;Tubular rear control arms and panhard rod;Spohn torque-arm and driveshaft loop;Spohn control arm relocation brackets;Airlift air bags;CE three-way shocks;Subframe connectors
Nitrous:MSD-6T;Jacobs Nitrous Mastermind;Compucar TB plate kit;NOS bottles, bottle warmer, and remote valve
The car has been 11.1s at 125 with 1.5x 60ft on a progressive 150 shot to protect the 4L60 and 7.5 differential that was in it. Ran 12s on motor leaving off-idle. Radio, AC, and airbags have been removed. Rear tires are MT ET Street 28x10.5. I have not started the car in a while and currently does not have a battery in it. I will be putting a battery in it so it can start. It's not perfect, but we have put a LOT of money in this car over the past 17 years.
Make a reasonable offer. Need to move this.
Also for sale is a Turbo Technologies modified turbo setup for this car. We bought it with plans to switch from nitrous to turbo and never got around to it. Kit is as we purchased it.
Hybrid T76/72;Delta gate wastegate;BOV;All the hot side plumbing past a single-brick converter;All the cold side plumbing
This was a street kit that the previous owner upgraded and modified. I have connected everything to ensure all the stuff bolts together and fits the car.
Make a reasonable offer. Need to move this too.
Text five-0-two eight-6-seven 9-two-one-one
Only shown by appointment
Might make someone a really sweet deal.
UPDATE 85,000 original miles.
not driven in rain
dougg01 is offline
Old 10-17-2017, 01:05 PM
dougg01's Avatar
Re: 1994 Formula Firebird street/strip
Do we still TTT...? Anyway....
dougg01 is offline
Old 03-20-2018, 04:03 PM
dougg01's Avatar
Still not willing to part it out, but can sell as a roller.
dougg01 is offline
