Seeking opinions on new CAT back
1995 Firebird with LT1 - currently have Corsa system behind Kooks long tubes. Engine is basically small block chevy motor with some tweaks.
Looking to replace with Flowmaster, Magnaflow or “door # 3” (suggestions welcome). Frankly the Corsa’s are too loud for my old ears after ~ 10 plus years. In addition, I am looking to gain an additional 0.5 to 1.0 inches of ground clearance. The Corsa at 5.0 inches deep currently has ~ 4.0 inches of ground clearance and is wearing a nice dent in the center section
Your thoughts?
Your thoughts?
Re: Seeking opinions on new CAT back
If Corsa is too loud, Flowmaster and Magnaflow are going to be too loud too. They're at least as loud as Corsa.
Unfortunately, I don't have any more info than that.
Mufflex makes excellent catbacks, using either Flowmaster Race-Series mufflers or Spintech. The Spintech mufflers are very civilized compared to the Flowmaster. I had the Mufflex 4.0" catback with the Flowmaster single in/single out muffler, fairly loud, and a heavy/annoying resonance at 2,500 RPM. I rode in a newer 4th Gen (LS1) Camaro belonging to the owner of Mufflex, with the Spintech single in/dual out muffler, and it seemed fairly quiet for a "performance" system.
Mufflex does not make a 3" catback though, only 3.5" and 4.0". And the 4.0" is a tight squeeze over the axle. Can't rattle because it is firmly wedged between the body and the upper panhard rod support. The 4.0" is intended for 5-600+ HP setups. But the 3.5" would fit OK. Try and find an online sample of the Spintech sound. Mufflex used to have a sound sample online, but I couldn't find it.
And Mufflex is right in Trenton, NJ, so you could have it installed there.
https://www.mufflex-performance.com/
https://www.mufflex-performance.com/...gle-cat-system
4.0"/Flowmaster
4.0"/Flowmaster
I feel the magnaflow is quiet at idle and mildly loud under load. I have mid length headers and no cats. Just cruising it is super quiet in the car then it roars at WOT.
