97 Camaro window problem
First off, I have read a lot about the 4th gen f-body windows and how their motors don't have enough power running to them and that they'll burn up that way.
My drivers window has seemed to be in great condition for the couple of months that I've had the car running.(It has rolled down fast, and rolled up fast, even though the passenger side is extremely sluggish). But today I was in a drive through and when I went to roll the window back up, it would not at all. I would hear the clicking sound that it makes under the steering wheel somewhere, but the window would never budge.
It has been down now for 7 hours, and I go out and check every few hours to see if it will work but it still won't. SO, does this sound like the motor, or could this be the switch or electrical? The reason I ask is also because I can sometimes roll the passenger window up and down from the drivers side, and other times I can only roll the passenger window down with the controls on the passenger side.
Re: 97 Camaro window problem
I'm going to move this. "Car Audio and Electronics" is not too busy, and is intended for audio and aftermarket electronic gadgets. Window motor problems are routinely covered on "General 67-02 F-Body Tech".
He includes comments on problems with the switches, the need for lubrication of the tracks, etc. Explains when you hear the clicking under the dash.
Another other thing that 97-up Fbody owners need to be aware of is the BCM (body control module) these are know to have a power window relay which has shoddy soldering and the 5 pins need to be de-soldered/re-soldered.
You will know because the radio and windows will start to work intermittently then stop working altogether.
This module is under the dash on the passenger side just below the glove box, google 97-up Fbody BCM repair.
Ask me how I know because I'm in the midst of doing these repairs now plus I'm adding the Autotrix window relay kits which bypass the BCM and put both windows on their own relay system, I hope this helps.
Personally - I've had this issue with both Driver and Passenger sides....
Both sides have been replaced with the Dorman Window Lift Motor and following the above Shoebox instructions....
Been years with Zero issues after doing that
I stopped using my driver side window but guiding it up with your hand and press the UP button fast usually works. Sucks I can't go to drive thru places and I got pulled over for tints and had to open my door (to talk to him) and I thought the cop was going to shoot me lol.
Same here held off on window motors while fixing other little things. Usually waiting a few hrs helps but my driver side is 100% dead the passenger side is slow and dies after 20 secs and have to wait hrs just to try and move it up and works. I heard there is a way to jump the window motor so it goes up if you're in an emergency weather wise. Good luck man.
