Front lower air dam deflector metal nut inserts
I bought '94 Trans Am without front lower air dam deflector. Noticed all square metal nut inserts missing in lower radiator support that air dam is screwed to. I was looking all over the internet and cannot find any. Is there a particular pn for these or are they part of the radiator support? What can I use as a replacement?
Re: Front lower air dam deflector metal nut inserts
Long time since I've done anything with the air dam, but aren't these the little square spring clips that push over the edge of the sheet metal support, placing the threads of the spring clip over the hole in the support? If so, those should be common/generic parts available at any decent auto parts store. Take a screw with you so you get the right size.
Model specific parts:
Clip Nuts | eBay
If that's not what they are I would check the 4th Gen parts manual, available here:
https://www.mediafire.com/?40mfgeoe4ctti
But finding anything in there is a challenge.
Clip Nuts | eBay
