Rear lower control arm & panhard rod bolt/ nut size
Old 07-13-2014, 12:43 PM
thoreightysix's Avatar
Question Rear lower control arm & panhard rod bolt/ nut size
hello,
I'm looking to replace my rear lower control arms and panhard rod for better handling. I know that I'll need new hardware, already had to replace one of the bolt/nuts on the panhard rod.
Need to know the size of the bolts / nuts for the rear lower control arms. I have came across the Spohn set you can buy, but would like to save some cash and upgrade the quality of the hardware.
As for the panhard rod. I'm guessing I need another set of these:
GM 11516933
GM 11515744
Thanks
thoreightysix is offline
Old 07-13-2014, 01:30 PM
Re: Rear lower control arm & panhard rod bolt/ nut size
If you look at the prices for the bolt and nut that you listed, you will be paying almost $4.00 for one nut and one bolt. Assuming the prices are similar for the LCA nuts and bolts, you would pay about $16. That's $4 more than the Spohn price, and it's top grade metric parts, plus the washers.
4) 12mm Grade 10.9 bolts (silver zinc plated)
(4) 12mm flanged head steel lock nuts (silver zinc plated)
(4) 12mm flat washers (silver zinc plated)
See more at:
http://www.spohn.net/shop/1993-1997-...dware-Kit.html
You can't buy higher quality than that.
I know there's shipping involved, but how much are you possibly going to save by hunting around a hardware store for parts that may even be Chinese counterfeits?
Injuneer is offline
Old 07-13-2014, 03:23 PM
Thanks for the prompt reply!
I guess I will go with the UMI set which is just a shade cheaper!
Now it's time to find out how hard the shop will hit me for installation & alignment. :/
Thanks!
Old 07-13-2014, 03:42 PM
Why would you need alignment? Unless you use aftermarket adjustable LCA's there is nothing to align. Even if they are adjustable, you would set them at the same length as the stock bar. Only subframe damage would cause a thrust angle problem. The install is also very easy to do yourself. That's where you can save money.
Injuneer is offline
Old 07-13-2014, 03:53 PM
Well, I usually like to do the work myself but no longer have a garage to work in. Can't work on it in the apartment complex parking lot, so I'm subjected to rolling the dice with a local shop. It sucks.
Old 07-14-2014, 05:33 PM
FirebirdGT's Avatar
Thanks!
Although I do like UMI stuff, the lock nuts in their kit are inferior to the Spohn kit. UMI uses nylon lock nuts (which I would never put under the car) vs a prevailing torque nut which Spohn uses.
Up to you.
FirebirdGT is offline
Old 06-17-2018, 12:15 AM
slowpoke96z28's Avatar
It's been a few years, how are things working? FWIW, (at least in 2015) the bigger issue is the the sleeve that adapts the factory metric bolt to the 3/4" opening if you'e using a solid rod end. Once you stack the tolerances between the mount in the body, an OEM sized metric bolt, and the adapter sleeve to go from that bolt to the 3/4" hole in the ball, you still may have some play. May be less than stock bushing deflection, but disheartening still...
slowpoke96z28 is offline
Old 06-17-2018, 09:37 AM
The OP has not signed into this site since his last post above, almost 4 years ago.
Injuneer is offline
Old 06-18-2018, 01:21 AM
And i'm hoping he gets and sees an email for the thread, he'll be curious enough to check it out.
camarogeek
04-19-2012 01:01 PM
Silvershark
04-28-2006 07:35 AM
SBainsTA
11-10-2005 09:58 PM
Z95m6
08-30-2005 10:33 PM
Gripenfelter
08-16-2004 10:10 AM
Quick Reply: Rear lower control arm & panhard rod bolt/ nut size
