do wires make a difference
Old 06-12-2013, 12:39 PM
evilchevy's Avatar
I have been looking around to see if a coil and wire change will get me more hp and even more mpg and i have seen a lot of different thing i have seen wires that are the same size as stock or thicker, that they come in all different colors but i have headers so i know it will be getting hotter by the headers then what stock is, and for coils i hear the stock works just fine is that true is there does anyone make an aftermarket coil that works better ???
evilchevy is offline
Old 07-13-2013, 11:20 AM
v6sonoma's Avatar
Re: do wires make a difference
From what I have seen there is little to nothing to gain over the stock LS3 stuff.
v6sonoma is offline
Old 07-14-2013, 08:52 AM
parkers Z28's Avatar
They will make a difference if your engines has 700hp where you need a hotter spark. I'm not sure what is the best way to get more hp out of the 5th gen. look into getting a Cold air intake and better flowing exhaust
parkers Z28 is offline
Old 09-28-2013, 01:02 PM
SteveC's Avatar
Thumbs down Re: do wires make a difference
Sir, you have a 48K coil with a maximum 10" wire going straight to the spark plug, even with a high resistance wire, YOU CAN POWER UP FRANKENSTIEN WITH IT!!!
JMHO
SteveC
SteveC is offline
Old 10-28-2013, 08:05 PM
Mr99SS's Avatar
msd wires are cheap and work cant hurt ... especially with headers
Mr99SS is offline
Old 03-01-2015, 07:25 PM
You IP address indicates you are posting from Pakistan. Are there many 5th Gen Camaros there?
IP = Pakistan Kamalia Usf Dslam Central
Injuneer is offline
Old 03-26-2015, 04:09 PM
ZeeS7o7's Avatar
Camaro or Camel?
ZeeS7o7 is offline
Old 06-13-2016, 06:21 PM
LS1Nat's Avatar
Originally Posted by ZeeS7o7
Camaro or Camel?
LS1Nat is offline
Old 04-21-2018, 07:49 PM
BraydenMurphy33's Avatar
In a mostly stock engine you'll notice zero difference from swapping out the wires. Put your money into other mods if you want a performance increase. Nice bright colored wires look nicer though.
BraydenMurphy33 is offline
10-31-2016 11:09 AM
01-23-2015 01:13 PM
InfernalVortex
01-17-2015 09:35 AM
siguy
11-27-2014 10:07 AM
07-04-2005 05:00 PM
Quick Reply: do wires make a difference
