starter shim, (lt1)
Old 05-03-2007, 09:20 AM
afr lt1's Avatar
starter shim, (lt1)
ok, so in trying to diagnose my cars prob, a guy said I might need to shim my starter. As far as I knew, I did not need any shims b/c there were none to begin with. I dont know if aftermarket starters need to be shimmed or what.
So, who here has had to shim their starter? How do you do it? Am I completely wrong and I def. dont need a shim?
Thanks for the help.
afr lt1 is offline
Old 05-03-2007, 09:25 AM
pcgamer4life's Avatar
The only reason you'd need to shim your starter would be if the gear didn't line up with the flywheel correctly. Shims are universal, all they are are little peices of metal that align with the bolt holes of your starter to lower it's position to align the teeth with the flywheel. Some aftermarket starters come with them, some don't. At work, only about half of our Duralast starters come with a set of shims, then we sell them in ilke a 4 pack for a couple bucks.
Why did your friend say you'd need to shim it, is it having a hard time turning over?
pcgamer4life is offline
Old 05-03-2007, 11:13 AM
afr lt1's Avatar
I have an intermittant problem of the car not starting. I have power everywhere, and when I turn the key to START, I get one single click and nothin'....so that lead me to try "this and that" to get it to start. Well, I move the car a few inches and pop the clutch; this moves something(flywheel?) and the car then starts. I think the prob is mechanical, being that I can remedy it by doing the method stated above.
I was going to start investigating the VATS system until a guy mentioned the shim thing. I didn't see any shims when I took out the old starter , so I figured they werent necessary. So I described the prob to the guy and he said it probably needs shims.
afr lt1 is offline
Old 05-03-2007, 11:34 AM
shoebox's Avatar
http://shbox.com/1/starter_gear.jpg
Any time you change the starter, you may need shims. It depends on how that particular starter mates to the block.
shoebox is offline
Old 05-03-2007, 03:37 PM
It's possible, but seems unlikely... generally starters have enough torque to turn the engine over even if they aren't perfectly lined up. The click you're hearing might be the starter drive gear engaging, and it's just not spinning. Have your starter tested somewhere. If that checks out fine, then I'd look into your ignition switch, probably not VATS related directly though.
Off topic: Shoebox, is that a diagram from All Data? I just got it installed a few weeks ago on my laptop. And I had no idea you're from Little Rock, I live in benton, like 30 minutes from you. We should meet up some time. I'll be going to UCA next year.
Old 05-03-2007, 04:10 PM
shoebox's Avatar
No, it is from a factory manual. My daughter graduated from UCA a few years back.
shoebox is offline
Old 05-03-2007, 05:09 PM
afr lt1's Avatar
yes, I have asked around and it is probably has nothing to do with shims.
- I am now going to check out the lock cylinder and ignition switch.
afr lt1 is offline
Old 11-14-2018, 10:25 AM
Ja Pe's Avatar
Re: starter shim, (lt1)
Did you ever figure out the problem ? I have a 94 lt1 firebird I just changed the starter on and it still makes that single click. Fired right up when i put the new starter in and now it just makes the same click noise. Some guy told me I need to put shims in my starter.
Ja Pe is offline
Old 11-14-2018, 01:28 PM
Checking the clearance between the starter gear and the ring gear will tell you if you need shims. Unfortunately, not easy to do. Shoebox gave a link to reference on his site, but here it is again:
Injuneer is offline
aidens z
08-22-2008 07:22 PM
speedcrazy
05-27-2004 07:34 PM
96z
05-21-2003 03:39 PM
BiohazardLT1
02-06-2003 05:27 AM
Quick Reply: starter shim, (lt1)
